Hello, My name is kenny tompkins. i have a problem with my fender bassman amp that no tech in my area can figure out. i was hoping to run this by you and see if you've ever encountered this problem before. The Problem is: the amp sat in storage for about 4 years in reasonable condidtions. The power chord was lost during this time. when i got it out of storage, i bought a new power chord at staples, it was made for computers but fit the chord jack perfectly. when i plugged it in and turned it on , it sounded as good as the day i bought it. i played for about 20 minutes and then the problem appeared. All of the sudden, the amp seemed to grab the guitar signal and pitch bend it toward the top register. much like a car engine slowly rising in rpms. its a hard sound to describe. i turned off the amp and checked all chords. turned it back on and it worked again. this time it took about 30 seconds for the problem to appear. the "sudden pitch bender" thing happened. I thought it might be due to the new power chord but could not find info on this subject. i also thought it might be a heat related issue because it took a few minutes to happen when first turned on. Do you have any advice on this topic? Thanks very much for time. Kenny Tompkins
  • 4,234 Answers
I can't confirm this without testing the amp directly, but I would suspect bad capacitors in the pre-amp section. Some of them may have dried out a bit over time. Anyone that is familiar with guitar amps should be able to resolve this for you. The other thing to check is the 12AX7A tubes inside. Swap them around and see if the symptom changes. You may also have a bad tube.
Keep us posted.
Dan
Posted on Jun 27, 2008
My fender bassman 100 amplifier blows fuses why?
something dead shorting after the fuse
May 26, 2017 | Cars & Trucks
Aa16630
What indicates the caps are bad. What does modded or come point to point saying?
Jul 09, 2014 | Audio Players & Recorders
110 volts 220 volts
If not, you can buy a voltage converter
Mar 08, 2014 | Fender Music
I have a little Fender Frontman Reverb, 15Amp, a versitile and handy amp, closed back and dual front ported with extension and headphone outputs. Went to use it one day and as soon as I turned it on I got...
It sounds like one of the preamp valves is faulty or other components in that area of the circuit causing a positive feedback loop which is generating the noise. You need to take it to an authorised Fender repairer in your area. Whereabouts are you?
Dec 13, 2017 | Fender ® Frontman 15R Electric Guitar...
I cant find my horn.. I have looked every where under the hood and cant not figure out where it is, if somone knows can they please help me??
i try always to keep things simple in life.with your car not running have someone push the horn on & off from inside.no manuals,no wiring diagrams,just let your ears & eyes guide you to it.
May 20, 2011 | 1993 Ford Festiva
1965 fender bassman. The Bb, B, and C on the E string have a phasing sound.BTW...I'm playing a P-bass thru the amp...
Seems that there are some harmonic distortions.
You can try to swap some tubes (12AX7), there could be just one tube who's messes up your sound.
If there isn't any change off this distortion, you must visit a technician.
Good luck,
Gerard
Dec 24, 2009 | Fender Audio Players & Recorders
Fender bassman 200 producing fuzzy tone
I would check all the connections, try switching different connections making sure it's not the jacks, if that doesn't work, try sending to company if under warranty.
hope this helps
Apr 01, 2008 | Audio Players & Recorders
Feedback from bass amp
first check capeciter in rectifier stage.
Oct 16, 2007 | 3Com SuperStack II advanced RPS...
82 people viewed this question
 Grubhead
Grubhead
