Question about Car Audio & Video
Tranmission had motor oil put in it by mystake dove it for one week befor i realised how to repair it the bands have just started sliping
  • 405 Answers
That's not good.
The best advice I can give you is drain the transmission fluid and remove the tranny filter(requires removal of transmission pan), flush several quarts of tranny fluid through with the pan removed to grab any residual oil,replace tranny filter with a new one, reinstall pan, re-fill tranny pan with proper oil and add a whole bottle of "Lucas Transmission Stabilizer". The stabilzer works wonders with the slipping, although if you keep driving it the way it is now you will at worst "grenade" your tranny, if you take the steps above you could still get a lot of life out of it provided no serious damage has already been done. Seek a mechanic if you are not familar with the disassembly mentioned above.
Good Luck
Hope this helps
Posted on Jun 27, 2008
I have a new motor in my car, but the car starts not wanting to go up hills or flat land, Is it the tranmission gone? It doesn't go when in reverse.
how can you go any were if the car dosent want to move if your saying it is sliping then you have transmision problems
Apr 23, 2012 | 1995 Plymouth Voyager
How to change engine oil and oil filter
Drain the oil out the bottom of the oil pan there is a plug its just a bolt be careful not to drain the tranmission fluid. after all oil is drained put plug back in. remove oil filter (probably goin to need oil filter wrench). put new oil filter in place of the old one put small amount of oil on the gasket on new oil filter this will help make it easier to remove next time. if you can fill new filter up with oil before installing this will prevent dry starting. fill motor with recomended oil type and amount. you can go to any auto parts store they will set you up with everything you need an tell you the correct amounts. They even sell dvds now that will give you step by step instructions if you need further help.
Nov 11, 2010 | 2000 Mazda 626
1998 honda accord trans is sliping can i ajust the bands on it an how do i do it
hi just a quick one, have you tried checking the oil? i gather this is an auto, if so, best way to check oil on an automatic is to start the car, then check the dip stick, as most people check the oil in the box lie they do the engine oil, but this is not the case with an automatic...hope this helps please vote thanks
Mar 03, 2010 | 1998 Honda Accord
2002 PT auto trans problem
there is no band to adjust for your problem,the only bands are for stopping movement in the trans to to go to reverse,if your transmission is whining it is a problem with the front pump assembly ,
Jan 01, 2010 | 2002 Chrysler PT Cruiser
I smell bad odar when I get in my car coming from
If you had a bad smell coming from the auto box then you want to get it drained and refilled with DEXTRON 2,,as the smell you got would have been the forward band slipping and burning linings as the pump could have been low in oil pressure..
so dont say bugger it she be ok ,as the price of another G/Box will be a lot and the labour even more so dont hang around belive me.. Ron
Oct 28, 2009 | 2004 Pontiac Grand Am
I have a eclipse 96 I tried to repair the
did you change fluid and filter this is just as important as an engine oil change. also a automatic transmission has things called bands that change the gears and hold overdrive in they also need adjusting every 30,000 miles. if not they will cause your transm,ission to slip. and burn up atf fluid.
Oct 26, 2009 | 2001 Mitsubishi Eclipse
Instrution for lower intake repair 3.4 camaro
remove all accessories from front of engine -alt and ps pump,then drain cooling system ,remove upper intake- remove valve covers then lower intake.Then take out push rods to remove gasket(keep push rods in order as exhaust rods ar longer-will bend valves if installed wrong-get a piece or card board and punch in 12 holes 6and 6opposite each other,then put push rods in it)please not their is an updated gasket set from FEL PRO that has all you need to repair the problem with updates torque specs for lower manifold in the box REMEMBER change motor oil befor starting-you can even pour a little oil onto lifters before putting lower back this is to get any coolant from upper block to run into pan before oil change,if not knocking will occur in the next week
Oct 04, 2009 | 1995 Chevrolet Camaro
Tranmission fluid
There is no tranmission fluid it uses the same oil as the motor does so when you change the oil you are putting clean oit in the tranmission also.
Oct 04, 2009 | 2007 Yamaha YZF-R6
I was told i need a tranmission computer where is it located on a
Check oil level if low fill. If not mayb it needs a service. bands and stuff need tighting.
May 16, 2009 | 1995 Isuzu Trooper
Excessive revving, even when I took the key out!!
is it burning oil or losing oil,driving it without oil may have damaged it,and putting too much oil and driving it may have pop the crank seals,inspect engine,decide what to do,not agood sign for motor,
Mar 04, 2009 | 1998 Ford Escort
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
