Question about Refrigerators
Coleman 5640 cooler
I need to replace the motor in my Coleman 5620 cooler but do not know how to remove the motor cover on the INSIDE of the cooler. I can not fine a repair manual.
The cover on the inside just pulls off. Inside/Outside fans pull off. 2 screws to dismount motor. Unscrew leads to terminal. Most truckstops carry the motor, otherwise search for Colman 5640.
Posted on Jul 26, 2009
My coleman electric cooler model 5640 does not get cold. The fan is on but it is not getting cold. Can I fix it?
For that to happen the electronic component that causes to cool the container already defective. It need to be replace with similar parts.
You can fix it, if you have some knowledge in electronic or electrical, know how to test of component parts, able to use test instruments.
If you don't have such knowledge, call a service technician to do that.
Good luck.
Jun 26, 2011 | Coleman Electric Cooler 40 Beverage Cooler
I have a model 5645 and it has stopped cooling
the outside fan can be replaced with a 92 x 25 mm computer cooling fan. Inside fan is a 60 x 10 mm. Remove the cover on the inside by pulling straight up. Plug it in and check if the metal heat sink on the inside is getting cold. If it does, then the problem is one or both of the fans.
Mar 15, 2010 | Coleman Electric Cooler 40 Beverage Cooler
Coleman model 5645 inside fan motor not working .. how do you open the cover to get to the fan and motor
pull straight up on the cover. Remove the 4 screws that hold the fan to the heat sink. You can then remove the 2 torx screws and remove the heat sink if you need to. Clip the wires as close to the bad fan as possible so you will have enough for the new fan.
Feb 01, 2010 | Coleman Electric Cooler 40 Beverage Cooler
Coleman 12-volt cooler stoped working/fan burned out
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
Jun 25, 2009 | Coleman Electric Cooler 40 Beverage Cooler
The 5640 Coleman cooler motor runs, but unit does not cool.
This is a thermoelectric (TE) cooler. There is no gas' to replace in it's cooling system. It is possible the thermoelectric coupler has gone bad. Unfortunately Coleman does not seem to offer a replacement part. If you Google thermoelectric couplers, maybe you can find something on the web. Good Luck.
May 25, 2009 | Coleman (100076) Compact Refrigerator
Coleman portable model 5640 cooler cord
Jo Ann,
You can google "coleman 5640" and quite a few websites will come up that offer repair parts and the cord is one of them. There are only three parts that you can still buy for that model cooler. The cord, the motor, and the removable tray. Hope this helps.
Marty
Aug 24, 2008 | Refrigerators
Have a coleman 5640 heating/cooling unit and the motor won't run unless just a tiny amount of pressure added?? Any suggestions?
Yes, to change from heat to cool is done by reversing the power plug that is close to the housing. Matching the blue on the plug(as I recall) makes it cool. The red to blue makes it a heater. If it is currently heating, the unit works fine, it just needs the polarity reversed.
Good luck,
Glenn
May 04, 2008 | Heating & Cooling
Refrigerators Logo
760 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
