Question about Toshiba Satellite A135-S4527 Notebook
WLAN problem Laptop keeps on restarting once WLAN is on. Problem persisting after formatting of hard disk with recovery CD.
Turn off WLAN cables, disconnect cables.when unit is on and you are in OS, go to Ddvice manager and see what is listed there.
Posted on Jun 29, 2008
Mi notebook acer aspire 3000LCi the only do is a an upper and i dont have a recovery disk
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
Oct 17, 2012 | Acer Aspire 5610-4648 Notebook
Tip
How to Restore a Laptop to Original Settings
Are you using your laptop from an extended period of time? If yes, then obviously your laptops' working speed has been decreased. You have huge number of files in your laptop's hard disk which cause low speed in processing the instructions. These files are not affecting the speed of laptop only but they also create problems to you when searching any particular file. Most of these files are not in use and probably these files will not be used in future. So, you should delete them from your hard disk.<br /> <br />What should be done to remove these files from your laptop's hard disk? There is a technique which is commonly used to make hard disk space free and keeps laptop with original setting. This technique is known as "Restoring". <br /> <br /> Sometime, your Windows operating system may crash and you don't know what to do. You can use the same tehnique.<br /> <br /> You can restore your laptop to original setting through the following instructions:<br /> To restore the laptop into its original setting you need a Recovery Disk which comes with the laptop and it is also available in market. Just get this CD and take the following steps:<br />- Place Recovery CD in your CD-Rom to operate the installation for restoring the laptop.<br />- Restart your laptop. Through restart, your laptop will auto detect the CD.<br />- After detecting the CD, your laptop will ask you "press any key to continue..." If your laptop will not ask that's mean there is something wrong with your booting setting, CD-ROM, or CD. Check them one by one and make sure everything is perfect.<br />- Press the keyboard key according to your laptop's model that brings up the recovery menu. Most common keys for the recovery menu are "F2," "F8," or "Ctrl" and "F11". <br />- Select a language from menu at the top of the screen and click on "Next" button. Language selection will show the instructions in your selected language.<br />- Select the field "PC Restore," "Repair Your Computer" or something similar. Then click on "Next" button.<br />- Then check on at "Restore" and then click "Enter". This will start the process of restoring the laptop.<br />- Once the restoring process has been completed, click on "Restart" button.<br /> Finally your laptop has been restored to the original setting and extra files have been deleted from your Hard Disk.
on Feb 22, 2011 | Computers & Internet
How to format my hard drive in dos
Rita,
Most computer recovery disks will perform the formatting for you. (This depends on the Manufacturer and Model though...)
If you put the recovery disk into the computer CD/DVD Drive and restart the computer - to boot to the disk, it should launch the recovery process and warn you that the hard drive will be erased and all data will be lost. This warning step is the recovery disks way of informing you that it will format the drive.
To boot to the CD/DVD you will need to tell the computer to do that. When the computer first turns on, you should see a brief message at the very beginning of the boot up process. The message will say something like: "Press Del for Boot Device" or "Press F12 for Boot Menu" or something of this sort. If your recovery disk is in the drive and you can get to the boot menu by pressing the key the computer prompts you to press, then you should be able to start up with that recovery disk.
Allowing the recovery disk to run through it's full process should format the hard drive and set your computer straight.
Make sure to run all of your updates once the recovery is complete and also make sure to install and update a good anti-virus software of some sort.
Nov 19, 2011 | Computers & Internet
Keeps on rebooting
What is the product and brand?
May 03, 2011 | Computers & Internet
What button do i hit at start up to reformat the hard drive on a compaq presario 700
Hi purple7558
did you mean format the hard disk and then install the operating system.?
press F10 to enter the bios setup, then set the boot sequence to cd rom first.
insert your windows cd into the cd rom.
save settings and restart. after the computer restarts it will detect that you enter cd then press enter.
the next process is the usual kind of format and install your operating system.
thanks&regards
Jan 10, 2011 | Compaq Presario 700 470024-192 Notebook
How to format my laptop
Normal 0
To format the hard disk and re-install Windows use the Windows installation CD, and the Windows Product Code on the label at the bottom of your laptop.
Boot up using the Windows installation CD and follow the instructions.
One of the installation early steps, the option to delete the existing partition, then create a new partition and then a full format on this partition (don't do a quick format) and complete the Windows installation.
Next install all of the Toshiba's computer/laptop device drives.
Next install the Windows service packs (SP2 & SP3 for XP, SP1 & SP2 for Vista)
Next Activate Windows via the Internet or by phone.
Next install your programs - Microsoft Office etc.
Next click on Start - Programs - Windows Update (for the latest updates).
Oct 16, 2010 | Toshiba Satellite Pro L300 Notebook
How i can format wyse x90l
You can not format the Windows Drive (referred to as windows partition) while the windows is running.
CAUTION: FORMATTING A PARTITION OR HARD DRIVE WILL RESULT IN ALL THE DATA BEING LOST.
But you can format any other drive or partition, to format a drive or partition other than the windows', open My computer right click on the drive icon and click format, press all the OKs and your drive will be formatted in a while.
To format whole hard drive, even the windows partition,
CAUTION: FORMATTING A DRIVE WILL RESULT IN LOOSING ALL THE DATA AND THE WINDOWS AS WELL.
Now back to business, to do a complete format you need a bootable cd, If you have your recovery disk or even a bootalble windows disk you can format everything.
Lets assume that you have a windows bootable cd, insert the disk while the laptop is starting (make sure that the computer boots up with the cd), let the setup load its files, then follow the instruction until you reach to the point when you can see your hard drives and its asking for formatting press F to format the drive which is highlighted.
Thats it.
Please feel free to ask me any further.
Apr 07, 2010 | WYSE X90e - C7-M 1.2 GHz ULV - RAM 512 MB...
I just received the system and recovery dics from Acer. When I insert the system disc, it loads and then times out with "please wait a moment..:
Then you may have a faulty hard drive, you didn't say why you had to get them, what happened? If your drive is OK? Then perhaps you need to format it first, with say UBCD, here download and burn to CD, and it has tools that will allow you to format and partition. www.ultimatebootcd.com/
Official instructions below.
Turn on you computer, if not already done. Place the Recovery Disk into your CD Drive. Restart the computer with the disk in the drive.
While the computer loads, you will be prompted to "Press any key to boot from disk." Press a key quickly as you are only given a few seconds to do so.
Follow the instructions on the screens to format your hard drive. When prompted to format the partition on your drive or to alter the partitions, select "Format" with the arrow and enter keys. Selecting "Alter" will not recover your computer.
Once the format is complete, you will be prompted to restart your computer. Accept, and while it boots again you will be prompted to "Boot from Disk," as in Step 2. Do not press any buttons this time as you have completed the formatting process already.
Windows will be reinstalled once formatting is complete. Remove the Recovery CD from the disk drive. Replace with the Driver Installation CD. Reinstall all your computers drivers with this CD.
  • If you accidentally select the "Alter" option in Step 3, restart your computer using the button beneath the Power button on your computer and follow Step 2 again. Store any files you want to keep on an external media, such as a CD or external hard drive.
  • You will lose all saved information on your hard drive, since using the Recovery CD will set your computer back to the factory default. Do not unplug or turn your computer off while the formatting or installation is in progress. Doing so may corrupt your hard drive and might render it unusable.
Feb 27, 2010 | Acer Aspire 5100-3357 Notebook
I need to restore my laptop to the factory settings. I have the recovery disks that came with it. What are the steps I need to take when using the operating system restore disc? I'm not familiar with...
Hello
First
what disk do you have?
one should be OS disk and a other should be drivers and software or a recovery disk.
if you have a label recovery disk start with that.
if you have an OS + driver disk start with the os disk.
put it in cd and press a key when it says so.
here is a very good guide to follow
after you installed the os then run the driver recovery disk just click next, its not that hard.
Sep 04, 2009 | HP Pavilion dv1000 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
