Question about Hitachi 60UX58B 60" Rear Projection Television
Hitache 61 The TV just made a pop and then turned itself off. I have tried everything the manual said to try but it will not turn on again. I sounded like some kind of fuse blowing or something like that. Are there fuses a consumer can access and replace? This TV was retired to our bedroom and still had a great picture and superb sound. I really would like to repair it rather than throw it away. Suggestions? Thank you. C Smtih
  • chris smith Nov 30, 2008
    I will follow-up on your suggestion and let you know how it worked.
    Thank you.
    Chris S
  • Hitachi Master
  • 3,459 Answers
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Nov 29, 2008
Heard a pop sound, lost color, now i get loud buzzing no picture lamp light flashing and it turns itself off and on
Color wheel need to be replaced, required color wheel is available in Samsung Parts, click the link to view image and price info.
Thanks.
Jun 25, 2011 | Samsung HL-P6163W 61" TV
61inch rear projection-tv does not come on . there is a clicking sound.
This solution pertains to anyone who owns an RCA 61"HGTV, that is not working. If your problem was that your TV made a big pop or explosion like noise, and then turned off and would/will not turn back on. We had this problem as well, and asked for help on this site, but we fixed the problem ourselves. We removed the back panel, and cleaned everything really good with a small hand vac/with a small brush attachment. Be very careful, as there are many small wired connections on the board, you don't want to rub hard with the brush, be gentle. After cleaning the back of TV really good, we replaced back panel, reconnected to cable, and we had TV once again. This may not fix all problems, but it's worth the try before buying new parts, which may no longer be avalible anyway. Thanks to all that suggested a solution for our problem, add this solution to your list as well. Thanks again !! Merry Christmas and Happy New Year to everyone !!!
Dec 07, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
easyab
Feb 28, 2010 | RCA Televison & Video
TV turns off by itself
Check the interlock switch on the rear lamp cover. Sounds like the cover might not be seating completely, allowing this safety switch to shut the TV off. When you remove the cover, it's just to the left of the big black plastic ventilation guide for the lamp, and it's a little tiny blue lever that moves up and down. Make sure the wires going to this switch are OK (not pulled out or 'hanging by a thread').
Jun 09, 2009 | Samsung HL-S6187W 61 in. HDTV
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
Televison & Video Logo
255 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
