Question about Brother IntelliFAX 3800 Plain Paper Laser Fax
Changed toner. now not working
The toner was changed/replaced, and now the fax machine doesn't work.
    Problem Solver:
  • 5 Answers
Take the cartridge back out. There are little contacts that allow the machine to know that the toner is in. Check to see that these are making contact between the cartridge and the machine itself. unplug it to do a hard reset too. Or smash it with your fist over and over to jar loss any poor connections!
Posted on Sep 22, 2008
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
I have a samsuns SF515 fax machine after changing the toner cartridge the message still appears "toner Empty" I have tried several new cartridges with the same issue.
if you have changed the drum/toner unit then the machine should have a fuse on top of the drum unit.I have come across some cartridges that don't have them on the unit.The fuse resets the fax so that it knows there is a new unit installed.If that does work then clear the machines memory using the control panel
Jun 14, 2010 | Samsung SF-515 Plain Paper Laser Fax
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine has toner error on screen.
sounds like you are using generic toner or rewfills, best to use oem toner
Jan 15, 2009 | Brother MFC-8460N All-In-One Printer
Toner
You need to use the [MENU], [< >] and [ENTER] keys to browse through the unit's menu. Find and enter the "System Setup" menu and then search for the "Ignore Toner" option. Press [ENTER] and change the setting to "ON". Press [ENTER to confirm, the, [STOP/CLEAR] to get out of the menu system. The unit should start printing all faxes in memory.
Now, if the unit does not clear the "Toner" error, you might be using a compatible toner that might not be as compatible as it should be. However , if the new toner is Samsung original, let me know for there might be another solution.
Be blessed.
Oct 16, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Faxes received are so light, the page looks blank
don't forget to try other fax-paper... your's might have already expired.... if this doesn't work... the printer's heater might need changing.
goodluck... hope this helps.
Feb 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Changing Drum on Fax Machine
yes its as simple as changing toner cartridge
Jan 17, 2008 | Office Equipment & Supplies
Toner level doesn`t reset
HAVE U TRIED CHANGING THE TONER HAPPY FAXING OMNIPRESENT
Sep 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 3800 Plain Paper Laser Fax Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
