Question about Nikon Travelite IV
Lens out of alignment
The lens seems to be out of alignment. I can focus the lens' with each eye but viewing together results in the one lens "dropping" slightly. Especially noticable when looking at a straight line object.
They retails for about $90 online - is it worth sending in for repair or just buying a new pair ?
Thanks ... Meschi
  • 1314 Answers
SOURCE: My Nikon Action 16 X 50--4.1 --serial number 715480BJ
id take thm back then the prisems may be out of line
Posted on Jan 29, 2008
SOURCE: Coolpix L6:
After I dropped the camera, the message reads Lens ERROR!
What can I do, I need my nikon coolpix L-6 for my nieces wedding 7-11
E me at teacher1217@yahoo.com
Posted on Jun 25, 2008
Char1ieJ
  • 100 Answers
SOURCE: Nikon E5700 ''Lens Error''
This is a fairly common problem with Nikon E5700 cameras. Sometimes, the problem is nothing more than the lens tried to extend, but bound on something and errored out. Removing the battery for a few minutes usually clears the problem. If it doesn't, you might GENTLY push on the lens -- like pushing it back into the camera body -- with the power OFF.
If that doesn't clear it up, you'll have to decide whether or not repair is worth it. I've seen the E5700 selling for around $300 on several websites. I paid $1200 for mine when it first hit the market. So, depreciation has set in. Nikon does a good job in repair and turn-around -- and they are not outrageously expensive. I had my E5700 serviced and back in 7 calendar days a couple years ago. They cleaned EVERYTHING -- and it's worked like a charm since then. Best wishes with the fix!
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
  • 112 Answers
SOURCE: Lens Caps
try...15165474200 or 1800 645 6678...hope this
Posted on Dec 02, 2008
lock123
  • 6831 Answers
SOURCE: I see a double image through my Nikon Travelite 12x24s
Hello Scott
While I am mostly a camera expert , I have seen the problem that you are describing. Inside the camera there is a little reflector which is used to invert the picture and focus it to the viewing eyes.
These reflectors are stuck to the camera casing using epoxy and the problem is that with time the epoxy becomes brittle and cracks. When it is cracked , the lens will move out of it's fixed posistion but the epoxy does not always break loose fully which is why you do not hear any rattle.
You could attempt to open it up and glue the lens back into posistion using some new epoxy , but you could possibly have some problems with the screws of they are not standard.
In this case ask a jeweler to repiar the binocular for you as this should not cost much to repiar...no more than $15.
Kind Regards
Andrea
Posted on Dec 30, 2009
Is the Raynox DCR 250 compatible with 75-300mm Canon lens?
Have a look at this page for discussion about this adapter. Depending on the lens you're using it with - the DOF can be extremely shallow and make focusing difficult. If you're in Auto Focus mode - try switching to manual and see if you can get better results.
Aug 21, 2012 | Canon EF 75-300mm f/4-5.6 II Lens
I have quite a lot of fungus inside my sigma mirror ultra lens, the front lenses were easy to get out and polish but I am concerned about dismantling the smaller rear lenses. Are there any complications to...
Holy Smokes, well if I were you right now I'd put it back together and send it to Sigma for repair cause you dismantle a lens like that there is no way you are going to align those lens elements without the proper equipment.
Using anything more then lens cleaner for camera optics will in fact remove the coating from the lens.
What you have isn't like the lenses from a "View" camera where it was possible to remove one lens group and replace with another but, those lenses were made and used 70 years ago.
Lens technology has changed a bit since then.
I had a manual focus Nikon F2.8 lens one time that had a coating separation on the front element that caused some wicked flare. I took eye glass cleaner and Windex to it to remove the rest of the coating so I could continue the shoot. I then sent the lens to Nikon for repair.
Best of luck with that one
Apr 27, 2011 | Cameras
I have a makusutove 150 1800 telescope and I cant seem to get it to focus correctly - it seems as though the mirrors are focussing the light behind the viewing lens. I can get a focussed image if I hold...
You do not have enough BACK-FOCUS, you need an extension tube for the focuser like this one:
http://www.skiesunlimited.net/index.php?CategoryID=132
Buy the correct size for the focuser hole--
Jan 21, 2011 | Tasco 49114500 Spacestation(r) 114mm...
Focus ring jammed, lens having been dropped
Yes, it's possible. Do you have a lens collimator and other equipment needed to make sure the lens elements are aligned properly when you put it back together? If not, I strongly suggest you leave the job to a properly-trained professional technician.
May 31, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Hi i have an optus telescope when i find a star in my view find or the spacestation orbitating the earth i find it in my view find and when i look through the lens on the scope i see notting and i have...
Your finder is not aligned with your telescope. During the day time focus on a distant small object with the telescope-- then without moving the telescope adjust the crosshairs in the finder to match the telescope.
Dec 27, 2008 | Optics
Pentax espio 140
subaru662,
can you see the lens in the finder move when you zoom out? if not ,the finder lens is stuck.
if it does move when zooming, see if you have a diopter adjustment wheel or sliding knob near the front lens of the finder. if so adjust the lens to your eye.
Jun 28, 2008 | Pentax Espio 140V 35mm Point and Shoot...
Yukon yd-100 lens removal for camera fitting seems like thred is broken
When you say lens, did you unscrew the eye piece or the actual lense? because the eyepiece is meant to fit your adaptor for 35mm cameras etc. but the actual front lense should be tightly sealed and thread locked to make your glass (scope) waterproof to some extent and to protect the alignment of the other lenses within your scope. If it is possible your local camera shop may have the ability to re-align and seal your scope, but if not do you have a warranty? and if not even that, if i were you i would align and accraglass your piece back together, it's a last ditch solution that should last for years.
Apr 27, 2008 | Yukon 100X (6-100x100) (6-100x100 mm)
What lens do i insert into scope to view the moon
The moon is big so use the 25mm. The Barlow will have a multiplication marking on it 2x 3x etc. A 2x Barlow lens will effectively double the power of the eyepiece you are using. Do not use the erecting eyepiece for anything other than land viewing. Erecting eyepieces generally reduce the amount of light reaching your eye and thus reduce brightness of the faint objects in the sky.
So basically just place the 25 mm lens in the focuser and point the scope at the moon and you will be amazed at what you can see and how bright it is.
Dec 30, 2007 | Tasco 350x50mm Refractor Novice Telescopes
Viewing planets and stars
The problem is you are way out of focus. Turn the focus knob alot, until the star image gets much much smaller. Keep going until it looks like a pin point or a star!. The spider vane and center black dot will disappear. This black dot is actually the secondary diagonal mirror reflection in the primary mirror. The peace signs are the secondary supports. Use the lowest power eye pieces. I would not use the Barlow lens that comes with this scope as it very poor quality. Also, using this high power with this small an aperature (tube diamter) & unstable mount will be very difficult indeed. Invest in some wide angle, long eye relief low power lens. Use these for a while before going to higher powers.
Nov 19, 2007 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Nikon Travelite IV Logo
89 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
