Question about Systemax AOL Optimized PC (100607) PC Desktop
Computer shutting down I purchased a Systemax pc. some time ago. After turning on the computer is is just shutting off after 3 to 6 minutes.
    Problem Solver:
  • 6 Answers
This is mostlikly due to a virus or the computer is overheating and shutting down to avoid buring something up
Posted on Jun 27, 2008
Power option does not work when setting it to turn off monitor
The monitor has a separate power supply, 1 AC plug for the computer, 1 fro the monitor. The Power Options only apply to the Computer, your monitor will not shut off via the computer power options.
May 24, 2013 | Systemax Ascent RTS A14 (980796) PC...
My computer has been in the process of shutting down for over 4 hours. I just purchased this computer less than 24 hours ago
This computer is faulty, I suggest you return it to where you purchased it for a warranty repair or replacement. If you try to fix it you most likely void your warranty.
Aug 21, 2011 | Compaq Computers & Internet
My pc shuts off at anytime
PC shuts down when CPU temp is high/Problem with CPU fan or there is a problem with BIOS Make sure its not running hot Upgrade BIOS on the computer
Jun 21, 2011 | Systemax AOL Optimized PC (100607) PC...
Blinking light on desktop computer and shutting down
check your motherboard!! if motherboard is a problem then your monitor will blink and gets off!
May 08, 2010 | Systemax Venture PC Desktop
I have a Systemax Venture computer that is 3 years old. Just developed a problem. Turn the computer on and after 20 to 30 seconds the computer shut down. What is wrong???
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Systemax Venture PC Desktop
Systemax laptop not shutting completely down
Try this ;
Buried deep inside Windows XP lurks a little-known program called shutdown that shuts down your system in a very fast � but orderly � way. Here's how to put an icon on your desktop that'll shut down your machine quickly:
1. Right-click any empty location on your desktop.
2. Click New, Shortcut.
The Create Shortcut Wizard appears.
3. In the Type the Location of the Item box, type shutdown -s -t 0.
It's important that you put spaces before each hyphen, that you have no spaces after each hyphen, and that you use a zero at the end.
4. Click Next. 5. In the Type a Name for This Shortcut box, use a name that will remind you that this button is for a very quick shut down.
6. Click Finish.
Jan 15, 2009 | Systemax AOL Optimized PC (100607) PC...
SYSTEMAX COMPUTER POWER FAILURE
whenever u r connecting a harddrive to a computer, u have to make sure the jumper settings are correct.
Nov 14, 2008 | Dell Inspiron 2200 Notebook
Computer booting problem
FIRST OF ALL TIGHTEN THE WIRINGS
this is what happened to me 2 times
first change ur hard disk drive (HDD) with any other of your may be friend if the problem fixes then it is okay if not t hen may be ur mother board or processor is bad
NOTE:BEFORE U DO ANY THING CONSULT ANY EXPERT PHYSICALLY OR UR PARENTS IF UR A CHILD
Dec 01, 2007 | Systemax Venture S519J (988868) PC Desktop
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Systemax AOL Optimized PC (100607) PC Desktop Logo
270 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
