Question about Dryers
I have a kenmore electric dryer 80 series, my question is the dryer run, but no heat the dryer running cool. How do I trouble shoot?
    Novelist:
  • 161 Answers
First make sure that you actually have 220 available. Unplug dryer and test accross two straight poles. 220 to each other 120 to middle. L shaped hole. Motor runs on 120 volts and can run on one leg. Next test if there is voltage accross the two terminals of the element. Most likely just a burned out element. But check for power. Take the back off and look right bottom. There will be a tube like casing with two heavier wires going in the side at the bottom Turn dryer on and test for voltage. If not check each thermostat for an open circuit. The usual culprit is the high limit on the element box. If so next step is to unplug dryer, remove lint filter and remove the two screws there. Pry the top up from the front. Use a butter knife or thin screwdriver to push in clips at the front crack. Prop it up and you will see a flat metal strap holding the heater tube at the left rear. 5/16 socket. Remove screw and push element tube back. Go in back and remove wires from element. The element is held in place with usually just one screw pull it out and look for a broken coil. Elements cost anywhere from $9 to $25 Take the old one in or use the model #. The new one might not look exactly like the old but will fit. Thermostats cost about the same. After you fix the dryer you MUST check for blocked vent hoses etc. as this is a common cause for burned elements and thermostats.
Posted on Jun 29, 2008
2 Suggested Answers
marka19
  • 1430 Answers
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Posted on Mar 28, 2010
Kenmore gas dryer 80 series runs but, will not heat. Should I replace the igniter if there is no light seen when lower panel is off and the dryer is running?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Kenmore 63942 Dryer
We have a Kenmore 80 series dryer. When we use it their is no heat and it takes more than 3 cycles to dry the clothes. We can not find the manual to trouble shoot.HELP
heatman101
Jul 02, 2011 | Kenmore Washing Machines
OUR KENMORE 80 SERIES DRYER DOES RUN BUT DOESN'T HEAT AT ALL. PLEASE HELP!
If it was the fuse the dryer would not run.
I suspect the smaller limit at the top of the heater chamber
Number 1 in this photo.
clean her up
Service manual
Mar 15, 2011 | Kenmore 62802 Electric Dryer
Kenmore 80 series dryer starts(runs) but will not give off any heat?
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 07, 2010 | Kenmore 65924 Electric Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
DRYER RUNS, BUT WILL NOT HEAT
Do you have fuses or breaker? If you have fuses one fuse may be burnt out.
Jul 12, 2010 | Kenmore 62822 Electric Dryer
I have a kenmore series 80 electric dryer. It will will run for around a minute and then cut off. seems to be over heating. when I turn the heat setting down to the lowest setting it will run longer. If I...
that sounds like the dryer motor going bad,most of the time they run alittle then stop,or when you push the start button it just buzzes-mike
Mar 02, 2010 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
