Question about Bose Lifestyle 28 System
Speakers have cracking especialy with dee bass sounds
    Problem Solver:
  • 9 Answers
You may not like this but in the audoi/video community bose is overpriced middle of the road HTIB broduct. you can get a better system for a LOT less than what you payed.
As for the speaker issue' they are bottoming out because those drivers that they use AKA. The cheap $35.00 woofers and $2.00 tweeters were not meant for the application that they use them for, they are the same drivers that they use in their bookshelf speakers and are being ovelrloaded by the extreme LFE and HF content that is being fored through them.
I am surprised the woofers havent blown by now.
Posted on Jul 27, 2008
Distorted sound
It is very possible that a speaker is bad. If you have the connections, try connecting external speakers to the TV to see if it still has the distortion. If so, then the audio output on the TV is bad.
Jan 12, 2014 | Televison & Video
1522 hc bass speaker no sound
You should check speakers impedance, and if the speaker show some between 5 to 7Ohm then go check your crossover input jack connector for cracked solder joints, hope this helps.
Sep 02, 2013 | Audio Players & Recorders
Only bass driver working on the pair. tweeter and mid range cones not working.
hi,
check the tweeter and mid range. its coil may become faulty.
for checking the speakers carefully remove the speakers one by one, remove its connections.
and check the speakers with a AAA cell. is it producing cracking sound. if not the speakers coils are burned.
ok
Feb 01, 2011 | Mission 782 Main / Stereo Speaker
"pop" in speaker when turned up
more likely your deck is just running out of power. another cause is the speaker leads could be hitting the metal of the car with the bass, check for clearance.
May 19, 2010 | Alpine SPS-609 Car Subwoofer
How do I get more bass out of the system?
To get a better bass output from the sub. The best place is in the corner next to a wall. Doing that is called corner loading. Like you put a firecracker on your hand you might just get burned,buy if you close your hand...you will have to goto ER. And it is not a boomy sub. Small 5 1/4" woofers.You wand good bass? Take it back and buy klipche. Great sound and bass for a decent price.Or go all out and buy the Bob's Sunfire sub. and tick off all your neighbors. that little thing really pounds. I own two. When I played twister, My celing in my new home cracked. I got picts. If you want something simple like the 321,try Kef instant home therei <<spelling. Has a 10" sub.Bought for my father. Sounds great. Just 2speakers DVD/CD/Radio unit and sub.Simple one wire hook-up. and speakers.
Hope you are able to use this info.
Todd
Oct 29, 2009 | Bose Cinemate Digital Home Theater System...
Bass in Car Gone, i don't know why!!!
Does the amplifier power up? If so, then check the voltage at the outputs...sounds like the outputs fried. Also, check the RCA cable to make sure it is getting a signal to the amplifier.
Jul 08, 2008 | Pioneer TS-W301R Car Subwoofer
Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
Dec 31, 2007 | Logitech Z-5300 Computer Speakers
Logitech z-3 speaker system faulty wiring, pls help?
Obviously,the wires/cables have been damaged. Thus,the desired results of the sound system were compromised.Yes, the damage that the wires incurred can be remedied.However,for us to have peace of mind and eliminate the worries of the pc itself getting affected, which is more going to be more problematic,call up the store where you purchased the speaker and inquire from them if they can replace the wires,probably with or without you entailing any additional cost or expense.Logitech is a well known brand and it has a wide array of replacement items that goes with the products they are selling.
Sep 25, 2007 | Logitech Z-340 Computer Speakers
"cracking" noise
Your subwoofer is not capable of playing as loud as you want it to. That sound is the woofer reaching its limit. If you have any bass tone setting on your receiver set them to flat. If there are any other bass settings i.e contour, loudness boost etc turn them off. You can also try putting the woofer into a corner. This will increase the output. Closer to you would also be louder. Otherwise you need a sub with more output. Don't let the power rating fool you when you get a new one.
Aug 26, 2007 | Acoustic Research ARS108 Speaker
Bose Lifestyle 28 System Logo
95 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
