Question about Uniden Lands Phones
Need to record a new greeting and can't figure out how to on my uniden phone
  • peterjone632 Apr 21, 2009
    How do I record a greeting on my Uniden DECT 6.0?
I have a Uniden, I don't know if it's the same model as yours, but you just hold down the 'greeting' button until it says "record greeting", and then you record your greeting.
Posted on Oct 19, 2008
4 Suggested Answers
SOURCE: 5.8 ghz uniden phone
On your main unit, you have the "cid" button and then three buttons next to this, above the numerals. Those three, in order, are "redial" "menu" and "record". The record button is purely for recording a voice memo for another member of the household. Press "menu", use arrows (bottom right of unit) to go down to "answer setup" and this gives you the option to record your greeting. The prompts will then tell you the rest.
Posted on Oct 11, 2008
  • 58 Answers
SOURCE: Recording a Personalized Greeting
Press and hold greeting... it will ask for a new greeting... Record new greeting and then press greeting button again.
Posted on Feb 25, 2010
  • 102366 Answers
SOURCE: need to re-record greeting on
Select the model of your phone from the list at
http://uniden.com/index/manuals_results.cfm?cat=1
Posted on Feb 12, 2011
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Need to know how to record on the uniden 1480-4
Access the answering system from any handset by opening the menu and selecting "Ans. Setup". Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
Press 8 (RecNewGreeting).
Wait for the system to say "Record greeting," then begin speaking.
When you're finished, press 8 to stop recording. The system plays back your new greeting.
To keep this greeting, press End. To re-record it, go back to step 2.
If you need a manual, you can download one here.
Oct 25, 2011 | Uniden DECT 6.0 Cordless Phone ID
I want to change my answering machine greeting
For the DECT2180, press Mesage/Mute on any handset to access the answering system. Wait for the announcements to be finished or press 5 to skip. Then press 8. Wait for the message "record greeting" then begin speaking. Press 8 to stop recording. The system will play back the greeting. Press End to save the greeting and exit the system.
For the DECT2080, press and hold Greet on the base. When you hear "record greeting", start speaking your message. Press Greet again or the play/stop button to stop recording your message. Press Greet again to play back the current outgoing message.
Which Uniden do you have? There are several models. Manuals for all of the current ones are here: http://www.uniden.com/index/manuals_results.cfm?cat=59 .
Most models will be similar. Setting a new message when you call into the system is a totally different issue and not all Uniden phones support the feature. Read your manual.
I hope this helps.
Jan 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I record a greeting on the Uniden cxa/5698?
With the phone in standby, press [greet]. While the preset message is playing, press and hold [greet] again. You will hear the announcement "Record greeting" and a confirmation tone.
If you already have a greeting recorded, you can delete the current one and then record a new greeting. While the current greeting is playing, press (delete). And then start over with the first.
Start recording your message. You will have thirty seconds, and the message counter will count down.
When you are finished recording your greeting, press [greet], (play/stop) or [set]. You hear a confirmation tone, and then your greeting plays back for you.
The full instructions begin on page 45 of the manual.
Jan 06, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
How do i record a personal message on the answering machine of my Uniden DECT1480?
Record a Personal Greeting
1. Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
2. Press 8 (RecNewGreeting).
3. Wait for the system to say "Record greeting," then begin speaking.
4. When you're finished, press 8 to stop recording. The system plays back your new greeting.
5. To keep this greeting, press End. To re-record it, go back to step 2.
Or you can get the manual on the link below page 17.
Good Luck
Nov 08, 2010 | Uniden DECT 6.0 Cordless Phone ID
Feb 25, 2010 | Uniden 5.8GHz Cordless Phone
I recently bought a dect 6.0 digital answering system,and a friend put the first message on for me,then lost the manual,and now I can't figure out how to record a new message.Help!
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
  1. Press the Message icon (letter)/mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
New answer machine
YOU FIRST HAVE TO PRESS THE BUTTON WITH AN EVELOPE BY THE WORD MUTE ON THE HANDSET, THEN PRESS NUMBER 5 THEN NUMBER 8, RECORD GREETING THEN PRESS 8 TO CONFIRM.
Aug 08, 2009 | Uniden Cordless Phone
Greeting message
On most uniden phones, just hold down the greeeting button for 2 or 3 seconds and you can record a new greeting. You can find your owner's manual online for free in PDF format at Uniden's website
Mar 23, 2009 | Uniden Cordless Phone
Lands Phones Logo
432 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
