My epson rx 620 printer says there is a paper jam. It hasn't been used in a little while and last time it was there was no paper jam. How can I fix this error message? When I turn it on the paper feed seems to run for too long.
  • herriot Jul 15, 2008
    It says to press the color button to clear the jam. When I press it it just says the same thing again. I have tried pressing the OK button, the stop button and the cancel button to no avail.
    When I turn it on the paper feed seems to run for too long.I hope someone can help me.
    Thanks,
    Herriot
  • herriot Jul 16, 2008
    Comment by herriot, posted on Jul 15, 2008
    Thanks,
    Herriot
    Guru:
  • 1,342 Answers
Try re-setting the printer:
Turn off the printer. Hold down The Stop Button And The B & W Button. Turn on
the printer while holding the buttons down printer will reset.
Posted on Jul 16, 2008
  • 19,396 Answers
Inspect the internal part of the printer looking for fragments of paper.
Turn printer upside down to release eventual foreign objects stuck inside the printer.
Try playing with traction wheels.
Sometimes this tricks can fix the problem.
Posted on Jul 17, 2008
  • 813 Answers
U have to change roler your roler has been damged becous of that u have get error your paper is jammed
u have to with a good printer repairer
  • 691 Answers
The chances are that if there is no paper evident and the machine thinks there is, then there is something stuck near the paper sensor flag.
Take a thick piece of A5 card - like the back off a shorthand notepad. Start to push it through the paper path from the exit side i.e. from the front of the printer to the back. When you get to the rollers that are just behind the carriage, lift the rollers with your finger to help get the card through.
Make sure the card remains about 10cm away from the far right side as you look at the front of the printer as this is where the sensor flag is. If you push the card into the sensor flag, you may break it off.
Once you get the card through the sprung loaded rollers, tip the printer onto it's back - so are in effect pushing the card downwards. Work the card in and out. If you have a vacuum cleaner with a narrow nozzle, you can place this into the other side where the paper would normally go as the suction may help to remove the obstruction.
It's a bit fiddly and awkward but I found this to be a reliable method of removing bits and bobs from paper feed paths.
If nothing comes out and the error message remains then it is likely that the sensor flag is broken or just stuck. you can remove the covers of the machine to get to the sheet feeder, and this is fairly easy to remove. Once removed you can see whether the flag is broken or stuck, or just has something in it.
If you want a service manual for the RX620 to help you get into the machine, the LOOK HERE.
  • Inky Fingers
    Inky Fingers Jul 16, 2008
    NEVER pull paper out backward through the auto sheet feeder where you stack the paper. It will break the drive mechanism and render the printer too expensive to fix. Always either remove the printer from the front or dis-assemble the casings and remove the ASF to free the paper.
    Genius:
  • 1,447 Answers
Hi-
Chances are you are having a hardware issue. Try turning it off and unplug it from power supply then after a few minutes plug it back and try to copy something. If issue persist, there is a hardware problem on paper sensor. call 562-276-4382 for servicer.
Thanks for using Fixya!
    Master:
  • 497 Answers
This error occurs even when the printer is a lil dusty inside...do clean it too.
Posted on Jul 15, 2008
    Sergeant:
  • 275 Answers
remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out. Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset. Try printing another document.
Posted on Jun 27, 2008
    Genius:
  • 1,011 Answers
Sir,
You can fix this problem by looking down into the paper feed area and you'll see a gray rubber wheel which is used to pull the paper through. U put your hand into a sock and soaked the end of the sock in rubbing alcohol so my middle finger rotate the rubber wheel and wipe off the fine, almost powdery paper residue. The wheel just needs to be cleaned so the rubber grips and pulls on sheet at time instead of 3 or 4 and then jamming. You can use matte finish paper often so the wheel gets dusted and needs cleaning every 100 sheets or less.
Thanks
Good Luck
"Don't forget to rate the Solution"
    Brigadier General:
  • 3,614 Answers
First try uninstall the printer driver on your PC, unplug all connections to the PC. once the driver is uninstall ed, connect again the printer to the PC. let your pc detect the printer then install the driver now.
let me know..
  • micromaster
    micromaster Jun 27, 2008
    • Open
      the cover to the printer and look inside to see if there are any pieces
      of paper or debris that may be blocking the print path.
    • Be sure to
      unplug the printer before touching anything internal to avoid electric
      shock.
    • If there is something blocking the print path, remove it, close
      the printer, and try printing again.
    • You can also check inside the
      printer to see if any components have come loose.
  • micromaster
    • Look at the paper feeder assembly to see if the paper is slipping.
    • If
      so, the problem might be the type of paper you are using.
    • The paper
      feeder requires some friction between the sheets of paper so the top
      sheet can be pulled into the printing chamber.
    • Because printers use
      many different kinds of printing paper, you should check the printer
      manual to determine the specific paper type for your printer.
    Novelist:
  • 121 Answers
Try taking the paper out and fan it like a deck of cards. The paper may have gotten stuck together. This happens sometimes. Usually it is caused from humidity. Keep me posted and if you have any questions feel free to ask.
Thanks - Tech101
  • Justin Jun 27, 2008
    One thing to add. As far as clearing the error message after you unjam it there should be a reset job button or a button that says clear. If you have one of these buttons press them. If not a quick resolution would be to disconnect power to the printer after it is unjammed for about 1 minute and then plug power back in. This will clear the memory of the paper jam. Also if you found my solution helpful please rate it when you get a chance.
    Thanks - Tech101
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
Paper jam in px 710
The next step it to test each sensor, both mechanically and electrically. Get really good light on the sensors, sometimes little hairs cause a false read. Verify that each sensor opens and closes electrically when actuated.
Sep 25, 2012 | Epson Artisan 710 AllInOne InkJet Printer
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
I had some paper jam in the machine, so I pulled it out. now it won't scan. It makes a lot of noise, Seems there is small amout of paper still stuck in there, How do I open it on the bottom to clear it...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 22, 2010 | Epson RX620 All-In-One InkJet Photo...
The light cyan printer head is clogged
this article might help
http://www.ccs-digital.com/cartridgeproblem.asp
Feb 23, 2009 | Epson RX620 All-In-One InkJet Photo...
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson Paper Jam Error
Jan 01, 2009 | Office Equipment & Supplies
Need a basic user manual for rx 620. Reason paper jam how to deal with it.
For troubleshooting guide here is the link
http://www.epson.com/cgi-bin/Store/support/erscripts/start_er.jsp?BV_UseBVCookie=yes&oid=44341
For interactive help
For the manual
http://files.support.epson.com/htmldocs/rx620_/rx620_rf/index.htm
pls dont 4get to rate solution, thanks!!
Apr 17, 2008 | Office Equipment & Supplies
4,457 people viewed this question
k24674
jasbo
jasbo
