The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Hi Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email [email protected]
