Question about SanDisk Sansa e250 MP3 Player
Sansa e250 hi bro,thnx for helping...i tried the sansa connect recovery tool...but my player is not recognized by it...i dont know what is happening,,,i formatted my player using HP USB Format earlier,which cause the prob...please help me
  • 8,596 Answers
These are the only methods I can think of to rescue it:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 28, 2008
I turn on my sansa e250 it goes to refresh database, then blanks
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Mar 30, 2009 | SanDisk Sansa e250 MP3 Player
Mp 3 player
You need to download the Sansa recovery Tool from Sandisk's website
Aug 22, 2008 | SanDisk Sansa e250 MP3 Player
Firmware update help pleaaasssss!!!!
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Try doing it this way its slightly different but if you goto the sandisk website thier is also a recovery tool you can download so have a look on the site then if you have trouble finding it then get back to me ok
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Computer won't read mp3 player
First, reset.
If that fails, then try to download the Sansa Connect Recovery Tool from:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
If that still fails, upgrade the firmware from the Sansa website
If that fails, uninstall the software from the installation CD and reinstall it from the Sansa website.
Feb 10, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250 firmware problem
Verify that the device DOES NOT say RHAPSODY on the back or E2**R. This would indicate the rhapsody version, whereas the firmware is totally different.
If it is simply a E200, try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
Best of Luck.
Please RATE my solution at the bottom.
Nov 28, 2007 | SanDisk Sansa e250 MP3 Player
Sansa mp3
Try this;
Best of Luck.
Nov 19, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 issue
Sounds like your music may have become corrupt.
You can follow these steps to erase and start anew.
Best of Luck.
Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
Recovery Mode
Recovery Mode doesnt help if you dont load anything.
Try this;
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Nov 03, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is not turning on and charging.
i had the same problem.  the solution i used was to unscrew the back and pop the battery out and put it back in.  the only other option is to wait for the battery to die, which can take a while.  it's definitely a flaw with the sansa.  its happened twice within 6 months...  good luck
Oct 20, 2007 | SanDisk Sansa e250 MP3 Player
Cant get my mp3 player to work,
Try this ... Turn off the player. Make sure that when connecting the cord to the player you hear a "Click" confirming that the cord is securely plugged into the player. Put the Hold switch in the "Hold" position so you see the orange color on it. Hold the Record button on the side while pressing the power button. This brings you into recovery mode. This is where you can use the REcovery Tool from the Sandisk website to format and wipe the player to its original status. If the Recovery Tool does not work, then you must use the Firmware Updater tool, also on the Sandisk site.
Sep 30, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
