Question about Plantronics - Bluetooth Headset Plus Base & Headset
I CAN'T GET IT TO CONNECT - Plantronics - Bluetooth Headset Plus Base & Headset
  • marilynnL Jun 30, 2008
    I hooked up my new patronicss 222 to my new phone and It worked. I used it... I then must have touched something in the Bluetooth menu and it stopped working. I then deleted the find reloaded it and paired it again . It recognizes the piece and is in selection.. The blue light is flashing that my ear piece is on right? but the phone says its Not on or out of range... it just won't work HELP
  • helpme73 Jul 20, 2008
    same problem as DENEAN's I CAN'T GET IT TO problem. Cell phone has bluetooth 2.0. Bluetooth works for a while, then for some reason stops working. When I try to connect in the bluetooth menu, I get the error message " DEVICE OUT OF RANGE OR POWERED OFF. (although the power is on and the device is next to the bluetooth).
I had the same problem. I found my solution. Make sure that the earpiece was paired, and turn on. Reset your phone by turning the phone off. Once you turn it back on, It will connect to your earpiece. It worked for me. Hope it works for others.
Posted on Jul 22, 2008
  • 92 Answers
Have you made sure that your phone has bluetooth 2.0? that's the only way a bluetooth headset will work reliably.
Posted on Jun 27, 2008
What wires do I connect to a trombetta 974 1215 011
basic installation, use only if you feel it is related exactly to basic setup, refering to action you take with hooking up wries....
Wiring Diagram
1. Connect Load (A) to High Current stud (B)
2. Connect battery positive (C) to fuse (D)
3. Connect fuse (D) to High Current stud (E)
4. Connect Switch (F) to Coil stud (H)
5. Connect Ground Wire (J) to Coil stud (K)
Jun 24, 2014 | RVs
Cant connect to wifi
How is it not able to connect to wifi?
-Not able to see the wireless network.
-Not able to connect to the wireless network.
-Was able to connect before but now it is not able to connect.
Have you tried to connect it to another wifi connection?
Dec 17, 2012 | Nintendo DS Lite
Linksys WRT160N router problem
go to control panel--network and internet--n/w and sharing centre---manage wireless n/ws---remove all wireless n/ws u see there including ur n/w name......then click start--connect to---connect to ur n/w typing proper encryption keys
May 30, 2010 | Linksys WRT160N Wireless Router
Connecting my phone to my PC
Nettworking wizard will be opened after you are able to connect the phone. For that you must start PC Studio and select Connect. There you will fine various means to connect. Select USB and connect. Or BT connect. Then select a comm port one by one and try to connect. One of the comm ports will accept the phone and connec.
Aug 22, 2009 | Samsung SGH-U600
How to install a clutch?
the mechanic should place or connect the clutch pedal spring to the clutch pedal .connect the push rod to the clutch pedal.then connect the push rod to the clutch master cylinder then refill the clutch master cylinder .by means of pressure tube connect the clutch slave cylinder .then connect the clutch slave cylinder to the push rod .And the push rod connect it to the clutch pork. the clutch pork connect to the spring. then connect the fly wheel , the clutch linning ,the clutch disk ,the release bearing,then the clutch pork to the transmission shaft . then connect the transmission assembly.And you can goon with your date.
Aug 03, 2009 | Volkswagen Jetta Cars & Trucks
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
first you have to connect with the power
then use the printer cable to connect the printer with your pc.
If you can mention the printer i will tell how to connect with the pc
Normally in new printers they use the USB cables to connect printers.
OR the parallel port to connect printers like dot matrix ( in this port there are only one port are in the behind the CPU it is a normally biggest connector )
Nov 07, 2008 | Epson LX-300 Matrix Printer
Plantronics - Bluetooth Headset Plus Base & Headset Logo
60 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
