SOURCE: i dont have connection for
Same problem and it seems like no one has a solution.. For frikkin sakes can the developers do something
SOURCE: my luckywire can't connect
was the wire working before and is the wire fine now dosnot have any problem like you can check the wire with another computer is it ok working fine . if the wire is fine did you change anything on the ip settings if not and its the same computer you are using then just try 1 remove the wire and plug it both side fine and should here the click sound . 2 check in your computer the settings are DHCP or assigned. 3 if assigned then assign it acording to the range like all the connected device should be in same range like 192.168.0.1/192.168.0.2/so on . 4 try to go to cmd prompt and try typing ping and the router ip dose it get repply.or fail if fail you have problem with cable or the network adapter driver could just uninstall and reinstall the driver. please let me know later what happend thanks
