Question about Hoover Vacuums
Belt will not spin - Hoover Vacuums
    Problem Solver:
  • 17 Answers
3 things may be wrong. 1 - brush motor burned up or disconnected. 2 - belt damaged, stretched or missing cogs on belt. 3 - belt is turning but brush roller is not turning due to bearings froze. In all 3 of these cases, the vacuum should be taken in to a repair shop.
Posted on Jun 27, 2008
My Eurika 4D bagless upright will not pick up anything. The belt is not broke but the roller won't spin and there is verry little to no suction. Still makes all the notice but won't roll as easily
You say the belt is not broken and the roller does not spin. Does the motor that spins the belt turn. If the belt does not spin and the little drive motor spins then you will burn the belt out. Try to turn the roller by hand. Could be plugged up with dirt and the roller seized. The little drive motor could be burnt out. Take all hoses and areas out that any dirt could be in. No suction means something is plugged. Even your main suction hose could be plugged.
Mar 15, 2017 | Vacuums
Why wont the brushes spin on vacuum cleaner?
First, check to make sure that the roller is not hindered by a pulled string such from a carpet. Next check the BELT that drives the pulley. If the belt spins a little bit as if the electric motor is working and the belt is not broken, check the belt to see glazing. If it is glazed, it is not getting enough friction to spin the belt. Replace belt as needed.
Jul 29, 2014 | Miele Vacuums
Even if the flat belt is broken and the v belt loose shouldn't the shafts or something be spinning when I flip it over and turn it on? Nothing is spinning on mine
There is a tensioner pulley that drops when you drop the handle down. It squeezes the belt against the roller making it spin. This part often breaks as well. Replace the flat belt, and check to make sure the v belts edges aren't rounded. If they are and the edges are not crisp replace that belt as well. DO NOT put the v belt under the tensioner pulley. It will break should you do so. I'll include a link to the correct part # for that flat belt.
http://www.vacuummedic.com/product.php?id=6
Aug 18, 2012 | Hoover U5780-900 Windtunnel Cyclonic...
Eats belts immediately
HI There,
Usually when the belt breaks immediately, this indicates that your roller brush has gone bad and needs to be replaced. I have never seen the motor shaft being damaged and causing belts to break before. When the roller brush can't spin because it's bearings have worn out, the motor shaft continues to try and turn the belt, but since the belt can't spin the motor shaft at that point burns right through the belt.
To make sure that it's your roller brush, remove the brush from the vacuum cleaner, and hold it using just your two pointer finger tips, holding just the bearings caps at the end of the bar, and not the bar itself.
Try to spin the brush using your thumbs. Does the brush spin freely without resistance? It should spin completely around 3-4 times on each spin. If it doesn't spin, then your bar is bad.
If the brush doesn spin, and it continues to break belts, this means that the belt is being installed incorrectly, and is being pinched by the roller brush. Pull the belt forwards after installing to make sure the brush spins freely.
Hope this helped you,
Chris Jones
GoVacuum.com
May 01, 2010 | Dirt Devil M086355 Bagged Upright Vacuum
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
The brush won't spin - but the silver stem it on is spinning
The belt may look fine but it is stretched. The silver stem is the motor shaft. Replace the belt with a genuine one by model #. It will be 20-30% smaller. Check that your brush roll turns freely by hand. Pop the nylon caps off the end to remove hair and thread.
Aug 10, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Vacuums Logo
91 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
