Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
If you turn off the computer by holding the power button down for 15 seconds, then turn it back on, it will reboot.
I'm not sure this is your question. Could you restate it?
Reboot essentially means restarting the computer. This is two types
1. Warm Reboot: where you go to start on windows task bar and choose shut down but when prompted choose restart. This way computer shuts down momentarily and restarts!
2. Cold Reboot: By this means you choose to shut down and again when prompted choose shut down! This makes computer off completely until restart by pressing power button.
Booting is computer Lingo for above procedures!
In this new tower you are swttching to, does it have it's own power supply? And if so, what are the amps, and what are the amps on your old power supply? I have the K8N, and it needs at least 450W to run decent. Let me know?
There are many reasons why a computer may freeze or completely crash.
The most common reason is an overload in the memory. Computers have
a set amount of memory to work with (this is their RAM, or "Random
Access Memory"). If you attempt to do more with the computer
than it's capable of handling at one time, it may "crash"
in an attempt to save itself. Generally, the cause of this is generally
that too many programs are running at once for the computer to handle.
If you are not using a program, close it.
Conflicts between programs are other well-known reasons for crashes.
Programs such as virus detectors are notorious for conflicting with
other applications and utilities. If you notice that crashes are
occurring while the same two programs are running, try to avoid
running these two programs at the same time.
What Can I Do?
Take Notes
Your first step should be to pay attention to what was happening
at the time of the freeze or crash. Try to isolate the program
that may be causing problems (this can help prevent a further,
more damaging, crash). Is there a history of problems with a particular
program (or combination of programs) on your computer? Were too
many programs running at once? Was it a particular task you were
trying to do? See if you can form a hypothesis about the cause.
By understanding what may have caused it this time, you can attempt
to avoid future, similar occurrences.
Try to End the Program
Windows provides a "Task Manager" that lists all current
programs in operation. In Windows 9x & ME, this menu is brought
up by pressing Ctrl + Alt + Delete at the same time. In Windows
2000, after pressing Ctrl + Alt + Delete, click the "Task
List" button. In this menu, you can attempt to individually
close programs that are causing problems. If programs are unresponsive,
Windows will attempt to notify you of this in the Task Manager. If
you are able to effectively close the program causing problems,
save your work in all other open programs, and reboot your computer.
This will help to prevent further crashes, and give your system
a clean slate to work from again.
Reboot
If you are not able to effectively close the program in question,
you have several options. Please note that any changes in unsaved
documents WILL be lost in a system reboot.
With the Task Manager open, try pressing Ctrl + Alt + Delete once
more. Windows will attempt to reboot itself.
If the Task Manager does not respond, you still have a few options.
Check your computer's tower to see if there is a "Reset"
button (it will be in the general area of the normal "Power"
button, and should be slightly smaller than it). Press the "Reset"
button, and your computer should reboot.
If you are unable to find the "Reset" button or do not
have one, there is one final option to pursue. Find the "Power"
button on your computer's tower. Press and hold this button. You
will need to hold it for a few seconds (sometimes up to ten full
seconds). At some point, your computer should shut down completely.
If nothing happens, keep holding the button. Do not press and let
go without giving the computer a fair chance to shut down.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Constant rebooting of a computer can be cause by alot of reason the most common for this is due to oevrheating, to check if this is a overheating problem try to open the case of the tower and put a electric fan in front of the tower to coll it down then power ON thecomputer and if it booted up fine with a electric fan blowing on the tower we're sure that you need to add some colling device on the computer tower, But if still do the same thing the problem here is the power supply unit it needs a replacement already....
