Dynamode Internal Fax Modem 56K
I get a "SM56 Helper Error"
"Loop current too high, please close the application and check the telephone line connection"
I checked and everything seems all right, I even changed to a new modem. The fax does not work
I had same problem trying to receive faxes until i changed phone connections.
according to a motorola manual (link below) this has something to do with being connected to a "proper analog phone line".
i had the phone line running from wall to a newer gateway (maybe 8 months) dec 07 to a maybe 2 year old compaq. kept getting that loop current error on the compaq when trying to receive a fax until i elimated the gateway connection and plugged the wall right into the compaq.
here's a link that might help: http://downloadmirror.intel.com/12655/ENG/Motorola.htm
see section 6, troubleshooting. hope this helps...
Posted on Jul 15, 2008
Hi i cant access to the internet . error 633 please help me
This error means The modem is not installed or configured for Dial-Up Networking. You need to check for modem driver in your device manager and if not present do install it
Apr 10, 2011 | Arris Chipset 56K V.92 PCI Internal...
DFM 562IS (DFM-562IS) Modem: SIR PLEASE SEND ME ITS ALL FEATURES.......
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
K56flex
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
My modem cant work
633 - The port is already in use or is not configured for Remote Access dialout
This error can occur if:
The modem is actually in use - make sure you don't have other applications that are using the modem. Applications that can use the modem include fax software, terminal software (like HyperTerminal), as well as voice software including software that can make your modem an answering machine or speakerphone.
One way of seeing all running applications is to press CTRL+ALT+DEL and look at the Task List or Task Manager. This will display the actual program names - it may be difficult to pinpoint which, if any, programs are accessing the modem. Terminating tasks are about the only way - however, if you terminate certain tasks, your system may crash or become unstable.
The telephone.ini file is missing or damaged - If the telephone.ini file is missing or damaged, you can create a new one by running Tapiini.exe - this file is in the \windows\system folder. Before you run this, rename the telephone.ini file and reboot your PC if it already exists. Then, run the tapiini.exe file. This program will run very quickly and may not appear to do anything. You can verify the program created the telephone.ini file by searching for it.
The telephone.ini file is a Microsoft Windows file that stores settings for all TAPI-enabled applications including DUNS.
Make sure the modem named in the DUNS entry matches the name of your installed modem - You can check the name of your modem in ControlPanel->Modems.
Windows 95/98 - Can occur if the Unimodem TAPI file (unimdm.tsp) is missing or damaged. See MS KB Q150619
Windows XP - Can occur if another device's driver has a conflict with the modem driver. MS KB 324760 indicates this can occur with older Palm Desktop HotSynch Software.
Apr 21, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
Modemsoftwear
The Motorola SM56 modem driver package will work under 2000 and XP. It installs version 6.05 of the driver onto your system. It can be used for Data/Fax, Data/Fax/TAM and Data/Fax/TAM/Speakerphone Motorola modems (TAM stands for Telephone answering machine). Check the model number of your modem to see that it describes one of these functions.To download the drivers visit the URL listed below:
http://www.softwarepatch.com/utilities/motorola-sm56.html
It gives you access to all the required softwares.
Apr 20, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
DRIVERS MODEM MOTOROLA SM56 FOR XP
I need drivers for modem motorola sm56 for windows xp.
thanks from croatia
Jul 24, 2008 | Arris SM56 (SM-56-PCI) Modem
No loop current
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider. But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
Sep 13, 2006 | Philips PPF-531 Plain Paper Thermal...
Computers & Internet Logo
963 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
