Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Dwf50 Two flashing lights are :- fast40% and delicate 50%
My Hotpoint DWF50 has stopped and the Two flashing lights are :- fast40% and delicate 50%,can you let me what this fault is.
Take out and clean your lower and upper spray arms.
The bottom one had bits of chipped crockery in it.The upper one a bit of platic bag(?????) and some of the door seal rubber.
Mine works fine now.
No screw driver, no mop nor an expensive call out!!
Jimmy Martin
Posted on Jul 15, 2008
Dwf50 not cleaning dishes
If your "clean" dishes have a cloudy film, it might be hard water deposits. Here's a map to see if you have hard water.
Dec 20, 2013 | Hotpoint 24 in. FDW60 Free-standing...
My problem was eco & prewash lights flashing so I followed instructions on Fix Ya to reset which seemed tomwork machine went through complete sequence but then reverted back to lights flashing aga
Hi, not sure if its relevent but we have a hotpoint aquarius DWF50 machine, light flashed same at times, sometimes push the switches would not operate properly to select a program. Lately the pump for emptying water at the end of a cycle would continue to run even when it was empty for hours until you turned it off.
Before doing anything else, disconnect the mains lead.....
I checked the float sensor for water etc as advised ...nothing dry..then decided to take off the controller board as previously we had a problem with the relay being dry soldered to the circuit board...on the left hand side of the board I found two thin wires, black and black with grey stripe, one was not soldered correctly to the board..dry joint and pulled away as i tugged at it. Resoldered the joint properly, reassembled board and connectors to the door. Fitted screws back etc. That was a week ago...its been fine since.
No idea what the wires were attached to at the other end but they look like low ampage signal type wires perhaps from some sort of sensor...anyway they should have been soldered properly during manufacture...years ago. Hope that helps ofr gives you something more to go on.
Jan 13, 2013 | Hotpoint 24 in. FDW60 Free-standing...
40 and 50 degree lights are flashing on my free standing fdw60 hotpoint dish washer
Apr 15, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius DWF50 Dishwasher, cycle not starting getting flashing ECO/Fast lights, any ideas?
hotpoint dwf50 will not start, the fast wash and prewash buttons are flashing together.
Jul 05, 2008 | Dishwashers
Dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Jun 16, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint dishwasher dwf50
i had the same problem and like an idiot paid for hotpoint to come out and all the guy done was tip the dishwasher backwards to empty the water(which he didn't clean) and tell me that im using to much rinse aid and salt coz we use 4 in1 tabs hope this helps smiley
Mar 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
736 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
