Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso I have replaced the circuit boards and the level (water) sensor and it still won't work. If I push the stop/cancel button, the timer displays 7min and the extend spin and cycle signal (softer) lights come on. It also sounds a beep tone, but not in a regular pattern. What should be done next? Target practice? Thank you gain for your time. Mark
    Genius:
  • 1,028 Answers
Do you hear a low hum from pump? if so something may have pump blocked new style pump has 3 torx screws in bottom remove them and clean pump old syle was a lost cause drive splines in pump would strip and motor would not drive pump
Posted on Jun 28, 2008
2 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: whirlpool calypso
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Posted on Oct 31, 2008
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Whirlpool calypso
Oct 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Have a Whirlpool GEQ9800LW0 and it won't start. When I set the timer and push the start button nothing happens. The timer still makes it's usual clicking sound but the dryer won't start. What needs...
    Check power to the inlet valve, if absent let the program move forward and if the motor does not work either it is possible that thetimer though ticking is not contacting.
    So go back to check for the wash cycle, when start is pushed, inlet valve on, water comes in, water fills , triggers level sensors,washing starts with motor on.
    If there is no voltage on any parts ,the timer contactor is faulty
    Sep 19, 2010 | Whirlpool GEW9200L Electric Dryer
    Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
    LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
    If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
    Check if the drain hose at the back is kinked or blocked.
    Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
    Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
    Keep a container ready to collect water when you undo pump hose.
    Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
    Parts and diagrams available here.
    Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Kenmore elite calypso doesn't respond to buttons except cancel
    I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
    Good Luck, George S.
    Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Timer dosent count down
    HI, this is a simple fix here, you will need to replace the timer/control module. this will fix this issue. this specific device is ruined and, unable to initiate the wash cycle correctly due to circuit damage.
    May 18, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
    Lights,tries to run
    Sounds like you have a bad control board but could also be a pressure switch problem. You would have to have a technician check it out. The calypso machines were discontinued after a class action law suit. They have multiple issues and are not worth repairing. Save your money and buy a new machine.
    Jul 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
    LTE6234 Whirlpool Twin Thin Timer Broken?
    Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
    Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
    Whirlpool Calypso - Will not start
    You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
    Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
    Whirlpool Calypso GVW9959K Top Load Washer Logo
    Dan Webster
    Dan Webster
    Sal De
