Question about HP Officejet 6310 All-In-One InkJet Printer
HO 6310 Rest Power
Tried changing print cartridges and now get Reset Power. From the looks of web comments it does not look good.
Help?
Steve
  • as51367 Jul 17, 2008
    Printer tells me to change the left cartridge, so I did, twice and it still reads the same error. It also registers as no ink on the ink levels.
  • SSNs4ever Aug 23, 2008
    I had the same problem. My Officejet 6310xi All-in-one keeps going to power reset. I did all the troubleshooting at hp.com.
  • 40 Answers
+++++++to steve and SSNs4ever++++++++
with regard to the power reset try to plug-in the printer directly to the power from the wall.observed if the power module/box temperature change if it did change the temperature its okay but it did not try to replaced the power module..
+++++++to AS51367++++++++
try to clean the copper contacts of the printer but before you clean it unplug the power cable first..if the issue still occur/remain the printer is now defective and it needs to be repaired/replaced.....
send me feedback for further troubleshooting
Posted on Sep 01, 2008
How can i fix this problem
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Apr 24, 2012 | HP Officejet 6310 All-In-One InkJet...
Printer icon says door open. I have open and closed cartridge door and turned power on and off and nothing works. any suggestions?
Hi
If you replace new ink cartridge, remove and reinsert again the inrk cartridge. Then try to reboot again the printer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Jun 07, 2011 | HP Officejet 6310 All-In-One InkJet...
Hi there, I have a hp officejet 6310 all in one: I changed the black cartridge but it brings up an error message that the black ink is finished. Please help:(
Hi
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Now open again the printer door. Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
May 12, 2011 | HP Officejet 6310 All-In-One InkJet...
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
HP 6310 needs to reset power. Tried turning off
it may be the power supply itself! have any of you tried using a different power cord? the problem may not be in the printer but in the cord itself. i have 2 hp 6310's that were giving me the 'reset power' error. when i changed the POWER CORD, that error message went away and it went into the insert cartridges mode. good luck.
Nov 16, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP Officejet 5510 error "Remove & check color cartridge
04-26-201210:27 PM
8. Close cover
Mar 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp all in one 6310
If align cartridges never goes away, you must replace all ink cartridges for a sucessful alignment..
I'm afraid i;ve never heard of align PAPER
Dec 29, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-in-One ''Cartridge Error: Cartridge on ...''
Hi for solution do this
First put out of the printer the Ink Cartriges then
press 4 + # + OK this send you a info menu
with the nav. Keys go to CHECKSUM FOR RELOCK DATA IMPUT press Ok 5 times . Then Go out there by pressing Cancell Button ant there you go if this dosnt work at the 1rs time you need 2 o 3 times more to ensure relock data ok
bye :)
Nov 14, 2008 | HP Officejet 6310 All-In-One InkJet...
Hp 6310 Cartridge error
I contacted HP customer service and was given a solution that worked for this precise problem: "Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clearn, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom."
This worked for me. At least immediately. I hope it doesn't happen again.
Jul 17, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
187 people viewed this question
Seeker5211
Seeker5211
