Question about Garmin eTrex GPS Receiver
Garmin chart plotter not booting up.
I will check on the battery to see if that may be the issue. I will report back my findings. Thanks.
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the update. Incidentally, most batteries for this purpose are Lithium 3 volts, coin size. Often, battery removal also performs a reset if not replaced immediately.
Though my money is really on the firmware.
Cheers.
Posted on Jun 28, 2008
Why is there a flashing question mark on my gps. and why isn't it locating satlellites.. is it because I don't have a memory card in it.
No it has nothing to do with the memory card. The question mark means it cannot find satellites and it does not know where you are at. Because this is a chart plotter your antenna may have gone bad or the wiring for this device may have gone bad. check the wiring for it here:
http://static.garmincdn.com/pumac/GPSMAP3005C_InstallationInstructions.pdf
Mar 13, 2015 | Garmin GPS
Is their a internal battery in sitex colormax 11
Yes. There is a battery backup to store memory. Read all about the Sitex Colormax chart plotters here:
http://www.si-tex.com/product_manuals/Chart-Plotters-3-08.pdf
Apr 28, 2014 | SI-TEX COLORMAX 11 GPS Receiver
My GSD 21 is mated to a Garmin 3210. Bought both componants new. Every single year since new it works 2-3 trips. Then just doesn't come on. Have to send it back to garmin who so far have waranted...
The GSD 22 is discontinued. I would not buy any electronics that are discontinued, because there has to be a reason.
If I were in your shoes I would be looking a full change to either the brand leaders, Raymarine or Humminbird. I have had Humminbird since 2007 with a 798SI and since 2014 with a 998SI HD. 100% reliable for GPS and depth. Boat used twice a week May to October. The 998 has features to set a chart course and I do that when coming from Toronto to Port Credit. Humminbird also do full chart plotters, but in Georgian Bay, I wouldn't have thought necessary unless you use an auto-pilot. Uses Blue Chart maps.
You aren't the only one to have problems. Read the link below.
I did find this thought and there are others in the thread
http://www.thehulltruth.com/marine-electronics-forum/146766-installer-i-stumped-garmin-problem.html
Make certain that the transducer(s) cable is separated from any engine power cables. When those wires cross or are bundled together, the highly sensitive sonar signal gets polluted with high amp noise bleeding off the engine wires, and you're lucky to get any signal.
To test if this is the problem, shut your engines off and see if you get a good sonar view. Then start the engines and see if the same sonar quality is displayed. If it degrades, you've got the current bleeding problem.
I had this problem when I installed the new gear (Furuno 585, Airmar b60) and ended up re-routing the transducer cable using some "wire hangers" to keep the transducer cable away from the others. Now I get a firm fix on the bottom at all speeds and the only time the display gets lost is when I reverse the starboard engine, from air bubbles under the thru-hull.
GSD 21 with 3210 problems - Google Search
Mar 21, 2017 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
Data cards for Fununo 1850w
Furuno just stopped producing these models about a year ago. They use a special chart card. You can still purchase the cards from Navionics or C-map if you need to. I will tell you from experience that you should get your internal battery changed out if you havent done so already to keep from losing your settings and waypoints. The dealer will have to save them for you though and put them back on. Furuno made a GP7000 to replace this one and it's uses SDcards and is nothing like the rest of Furuno's product line. The best replacement for this unit is the Garmin GPSMAP 700 series. You can use your old furuno transducer if you have one (with an adapter plug). This garmin unit also has a built in GPS or you can use an external one. The 700 series will be shipped in April. Check out Garmin's website or mid-shore electronics.
Aug 29, 2009 | Furuno 1850w/Nt Gps Chartplotter C Map Nt...
GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
Mar 22, 2008 | Raymarine RL70CRC GPS Receiver
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
Garmin eTrex GPS Receiver Logo
79 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
