Question about Dishwashers
Error LE on display of a LG dishwasher model LDF 6180WW Leaves water in the bottom of unit
  • Anonymous Jul 18, 2008
    Ditto
  • 3,230 Answers
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
(Just copy and past the above link in your web browser)
Thanks
Posted on Mar 27, 2010
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Lg model ldf 7810st starts but after 2 min stops and displays LE
You may have a broken wire where the wires go up in the center towards the bottom. If you remove the kickplate and tug on the wiring see if you can find a broken wire. These are notorious for this problem. Hope this helps _MJ_
May 21, 2010 | LG Dishwashers
LE error message
Good Luck!!
Dec 11, 2009 | LG Dishwashers
LE error code
check you inlet and outlet water hoses, check for leaks and blockages
Jun 29, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Repair code LE and bottom is flooded
I don't know if this thread will help, but you can have a look here: http://www.howtomendit.com/answers.php?id=28214
If not try the LG website which has support and fault codes to assist you.
Jun 18, 2009 | LG 24 in. LDF 7811 Stainless Steel...
LG dishwasher wont clean top rack dishes
If the unit is cleaning the bottom dishes normally, try unplugging the unit for 5 minutes to reset the control board.  If that doesn't work, then the control board needs to be replaced.  The problem is that control board is not diverting the water to the upper wash arm during the cycle.  Possibly a program problem
May 30, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LE light on...not filling with water.
ACCORDING TO SERVICE MANUAL, THE "L.E." ERROR CODE SUGGESTS A LOCKED ROTOR ON THE WASH MOTOR. CHECK THE WASH IMPELLER FOR A FOREIGN OBJECT. IF IT SPINS FREELY, CHECK THE WIRING TO THE WASH MOTOR FOR LOOSE CONNECTION.
THE L.G.HAS HAD A HISTORY OF MOTOR PROBLEMS.
YOU SHOULD BE ABLE TO CANCEL THE PROGRAM AND DRAIN OUT THE WATER.
Apr 03, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
154 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
