Question about GE Microwave Ovens
I have the GE profile combo microwave & convection. I keep getting F4 code when ever I use the sensor buttons.
  • ssmith3708 Aug 23, 2008
    I just installed the new push button panel that I ordered thanks again for you help. Because I had and F3 code. Now that it is installed, when I push the beverage button, I get a beep and the F4 code. Were do I start?
  • GE Master
  • 9,086 Answers
F4 means your temperature sensor is shorted or coated with grease.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
My GE Profile JVM1790 convection microwave has issue. Was using the convection portion when a small spark and flame appeared and then went out and soot and smoke was all inside and now will not heat up...
Yep, that sounds very much like the heating element burned out. It happens. You should be able to get a replacement from the manufacturer's website... or there may be a list of repair centers in the manual - pick one & try to order the heating element through them.
Aug 13, 2014 | GE JVM1790 Convection / Microwave Oven
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
''Press Clock'' but can't press buttons, then beeps with F4 error
F4
Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor
Sep 07, 2009 | GE Microwave Ovens
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacesaver XL Sensor Microwave
You have a bad door swicth or a bad wiring connector to one of the door switches... secondary swicth or the door sense switch.
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
I AM VERY DISAPPOINTED IN GE 'S HELP WHERE THEY WANT TO CHARGE 9.99 DOLLARS FOR HELP ON MY MICROWAVE WHICH IS OUT OF WARRANTY. IT IS ALMOST 2 YEARS OLD
Hi AGAIN DIBARTRK
Now that you have indicated the make of your oven....... the fault codes for GE microwaves are as follows. I have given you all of them for you future reference. :)
F1 - ( open thermal sensor ), will occur below 190�F of cavity temperature within 15 minutes of starting convection, combination or roast cook.
F2 - ( shorted thermal sensor ), will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
Note: it will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted/open.
F3 - ( shorted key panel ), will occur if a shorted key panel is detected continuously over 60 seconds.
Note: It will take a minimum of 1 minute of run time before the F code will be displayed.
F4 ( open humidity sensor ), will occur if humidity sensor is detected as being open continuously over 5 seconds.
F5 - ( shorted humidity sensor ), will occur if humidity sensor is detected as being shorted continuously over 5 seconds.
Note: It will will take a minimum of 15 seconds after the magnetron is energized before the F4 or F5 code will be displayed if the humidity sensor is shorted/open. Also the unit must be plugged into a 120 volt outlet for at least 5 minutes before sensor is checked, this also applies after the humidity sensor has been changed. Before checking operation of new sensor allow init to be plugged in for at least 5 minutes.
F6 - ( shorted temperature probe ), will occur if temperature probe is detected as being open or not plugged into the receptacle. If probe is plugged in and "ProbE" is on display, check probe for continuity with ohm meter.
they are all different for different brands... It is much easier to get a solution from FixYa you actually tell us what sort of equipment you are having trouble with. :) Do I get a FixYa rating now... :)
regards
robotek
May 06, 2008 | Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
114 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
