Question about Toshiba TP43H95 43" Rear Projection Television
Color alignment: Colors just out of alignment. I was able to re-align colors and cross-bars with the convergence settings, but now, they jump-out almost immediately after adjustment. I have been told to re-place the stk392-110 and stk392-020 ic. Is this something a total novice should attempt? Thanks
Replaced one fuse, and the stk392-020 ic. The stk392-020 was not an original Toshiba part but the alignment is perfect and I didn't even have to make any adjustments.
Posted on Jun 28, 2008
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Colors are not aligned
Can't use the flash focus button or the convergence control crosses +s don't alignes red,blue,green colors.The tv have convergence problems,it dead.Must replaced 2 STK convergence ICS,and some or all it resistors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | Panasonic PT-53WX53 53" Rear Projection...
I'm having convergence problems, the three colors will not align
this is a free question you have posted--I know these sets very well---red and blue move, but not far enough?
sd tech
Feb 15, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Colors out of alignment
you moved this set huh? alignment is out, magnets slid out of place on align coils the a convergance alignment preformed (sometimes u get lucky and the coils can be put back perfect and then no alignment needed)
Nov 22, 2009 | Televison & Video
Cannot reset vertical convergance
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I have a zenith pvr5263dt projection television.when I turn it on the color is out of alignment, I go to the menu and in one section of setup cross hairs come up with the colors misaligned but it does not...
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Please let me know if you wish to do this and I'll provide more detailed instructions.
Dan
Sep 09, 2008 | Zenith Televison & Video
Tv set 48 inches projector..[jvc]
replace 2 X convergence ICs and align. Maybe burnt resistors as well.
easyab@hotmail.com
Calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
Jun 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Hitachi 53uwx10b Convergence
The grid (called an overlay) is put in place to fine-tune one of the colors, usually green. Once one color is adjusted perfectly, the other 2 colors are adjusted to match the first color. For example, if the convergence data is completely erased, the tech will set up the overlay and align the green using to the overlay, and then align the red to the green and then the blue to the green. If the alignment is being done after replacing the convergence IC's because one or 2 colors are slightly off in the corners, the green is usually very close to perfect and the use of the overlay is not absolutely necessary. It is pretty easy to align one color using the outer edges of the screen itself. If you do need the overlay it can be purchased from any Hitachi parts distributor such as Herman Panson, Fox or Union Electronics.
Mar 31, 2008 | Televison & Video
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Toshiba TP43H95 43" Rear Projection Television Logo
178 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
