Question about Dryers
Bosch WTA 3100 Dryer - The large round fuse which is fitted just where the electric cables enter the back of the machine has blown but I don't know what to call the part or where to get a replacement. The parts firm I approached says he needs more of a model number that WTA 3100GB but that's all that's on the machine.
  • micklambert Aug 08, 2008
    Same Machine.Mains light glows when switched on but it wont turn over. Checked the cut out on the door. It cuts in and out correctly ie when door opened or shut tight with mains light on or off accordingly. Must be standard prob. Views before I start stripping down?
textonor
  • 130 Answers
SOURCE: Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Posted on Jan 06, 2008
SOURCE: Bosch Axxis WTA 4400 dryer
if you can hear a whirring then the motor is probably spinning, and the problem may just be a broken belt.
If no sound, then probably power not getting to motor via PCB
Posted on Apr 26, 2008
maklean
  • 1665 Answers
SOURCE: Service Manual
http://www.servicetechhelp.com/index.php/downloads/6124
Posted on Jun 26, 2008
SOURCE: Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
Posted on Sep 08, 2008
canbruce75
  • 1776 Answers
SOURCE: bosch tumble dryer, model wta 4100 , no heat,
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Posted on Sep 12, 2009
All the lights come on but the dryer does not start
There is a resetable fuse inside the dryer but your going to have to remove the back of the machine to get to it if I remember correctly
May 27, 2012 | Bosch Axxis WTA 3510 Electric Dryer
Bosch wta 3100 no heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Where do I find the reset button on the Bosch WTA 3100 tumble dryer?
It would be at the rear of the machine. You need to remove the rear cover which is secured by Self-Tapping screws. Cover would be almost circular in shape and the button is in the position 10 o'clock looking from the rear.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | Bosch Dryers
Bosch Axxis WTA 3510 Electric Dryer. I changed the fuse but it won't turn. Could it be the motor because I don't hear any sound?
there is a switch next to the belt tension arm behind the motor that needs to be reset push the switch needs to be pushed to the right andthis should get your unit running as long as you have power
Sep 16, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I have a bosch dryer WTA3510. My dryer is 5 yrs old and it stopped working. Electrical power is good but the dryer doesn't turn. Is there a fuse on this machine?
Check for a blown thermal fuse. It's about an inch long and is usually located in the rear of the dryer attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Sorry for your trouble and I hope this helped. Best wishes.
No heat in my Bosch dryer. everything else works
Sep 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
How far should the dryer vent be from the wall to the dryer?
No, you do not want the dryer vent crushed at all. Go to Home Depot and find a 4 inch adjustable 90 or something along that line. The problem will be that your clothes will dry for alittle while and then you will stat noticing longer and longer dry times
Feb 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Drive Belt on BOSCH WTA 3003 dryer
No,It`s quite a difficult & fiddly job.
Nov 10, 2008 | Bosch Axxis WTA 3003 Electric Dryer
My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
Feb 24, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
98 people viewed this question
Top Dryers Experts
