Question about Miele 24 in. G643Vi Plus Built-In Dishwasher
Obtaining Miele Dishwasher parts
I need a new piece of the door latch for my Miele G643scvi dishwasher. I have the part and it will be simple to replace, but the internet parts suppliers don't seem to carry miele and the company web site doesn't list parts.
do you have any suggestions on where i could get the part?
Thanks
  • Anonymous May 16, 2009
    I'm facing the same problem.
Take a look here Amazon com Miele Dishwasher parts. Hope you can find something. cheers
Posted on Nov 22, 2014
Miele's US website lists a toll free call in # for parts under the customer service heading. I found them to be helpful and informed. See below:
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
Posted on Dec 24, 2009
I have Miele Dishwasher, Model G 892 SC U Plus and the serial number 27/64348342, and I need stainless steel front door panel to replace the black one supplied.
Posted on Dec 02, 2009
    Problem Solver:
  • 6 Answers
EBAY seller eservice001, seems to have most parts, replies to questions and prices are typically less than buying from the Miele agent in your country if not in Europe.
Posted on Sep 14, 2014
Door wont shut
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Miele Dishwashers
My GE dishwasher's door is stuck shut ~ I'm assuming a broken latch. I was told to fix the latch, the dishwasher has to be taken out from under the counter top (in order to get the door open). My...
Well I'll try to help you get this opened. I don't know how much space you have at the top side edge of the dishwasher. You need a long stiff rod like a metal clothes hanger straightened so it can reach from the side to a little past the dishwasher middle. You need to push it in between the door top and the dishwasher body up at the latch area. What holds the door closed is a flat metal piece with a plastic hook on the end facing down towards the floor. You need to try and get the rod under the metal piece and lift it slightly, hopefully to unhook the the door. If you can't do that, the only alternative is to pull hard on the door handle and you should be able to break the plastic part of the latch which will then have to be replaced. The part that should break is the top hook which would be an easy replacement, but I can't be sure thats all the damage to the latch that will happen. It may do some damage to the part inside the door also. This is last resort. I'll try to attach a parts breakdown of the tub so you can see the latch hook. Look at item #50
Jun 10, 2011 | GE Profile PDW9880NSS Stainless Steel...
Install awooden panel on miele g2183 dishwasher it cover the latch how do open the dishwasher
you either have an over hang on the panel to grip hold of and open the door or you fit a handle to the integrated dishwashers.
Jul 23, 2010 | Miele G2183SCSF Builtin Dishwasher
Dishwasher won't start
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
May 16, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
Indesit d63 dishwasher, door locked shut. took top off+got to latch, the plastic catch wouldn`t pull out of the latch. undid it all, all seems unbroken but cannot seem to arrange the latch so that it will...
check with whoever you order the latch from, usually parts are individual for electrical parts and never assume that the screw or washer will come with new one, save every piece.
Mar 09, 2010 | Indesit 24 in. D63 Free-standing...
Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
Aug 18, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
I need the rail stopper on the left hand side of the top rack. It is a plastic v shaped piece or I need the whole rail. Modle #G885 SC dishwasher miele do you know where I can order this?
The only place to order Miele parts is through Miele spare parts. You can find your nearest Miele office through their website. There are no copy parts available.
Aug 08, 2009 | Miele 24 in. G643Vi Plus Built-In...
GE Dishwasher GSD2000 door latch/sensor malfunctioning
The latch could need a simple adjustment or may require replacing.
Is the catch (the part that sticks out of the dishwasher, not the door part) loose?
Maybe try to loosen it (dont unscrew it completely) and re-adjust it to suit.
Hope this helps!?
Jun 18, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Apr 03, 2009 | Miele Incognito G858SCVi Built-in...
Miele 24 in. G643Vi Plus Built-In Dishwasher Logo
12,617 people viewed this question
Top Miele Dishwashers Experts
Mike
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
