My central air conditioning system does not seem to be sending out cold air
  • francis rivero May 11, 2010
    please be specific. if the unit is not cooling, it could be from a number of different source, is the compressor running?, is the fan outside running? please clarify....thanxs.
    Novelist:
  • 121 Answers
This could be 2 issues. 1 being a simple issue and the other requiring service.
First issue:
Make sure you have the thermostat on cool and not Fan.
Secondnd issue:
If the thermostat was on cool and not fan, It sounds like the freeon level is low in your system. This will cause the air to not be cold. You will need to contact your local heating and air conditioning shop and have them take a look at this. You may be low on freeon because of a leak in your system also. It is recommended you get your system checked and tuned up every year. The cost of this is usually between $50 and $90. It is a good idea because they can catch problems early on before they become larger problems. It also will also keep your central air system running efficiently and use less power compared to a system that has not been maintained. Keep me posted and if you found this helpful please rate accordingly.
Thanks - Tech101
Posted on Jun 27, 2008
2 Suggested Answers
  • 674 Answers
SOURCE: central air conditioning blowing out hot, not
Can you tell if your outside unit is running (the fan and compressor)? Sometimes it is hard to hear the compressor for the fan. If they are running then you possibly have a low refrigerant charge and need to have some added. Refrigerant pressures and temps can be checked to verify this. If they are not running then you need to find out why. If both the fan and compressor are not running then first make sure all the breakers and disconnects are closed. Then a bad contactor or capacitor could be the problem. If its just the compressor that's not running then it could still be the capacitor or maybe the compressor.
Posted on Apr 29, 2010
Testimonial: "Thanks, this is very helpful."
What model Air Conditioner compressor has a 4 piston configuration?
nothing in the small unit size ( 32.000 btu)
only company that made larger compressors were Carrier and they were for cold storage units
go google and type in---air condition compressors and see what site s show up
as you have not bothered to specify what system or application you have , it is difficult to be more precise
Feb 14, 2016 | Heating & Cooling
AIR CONDITIONING AND CENTRAL LOCKING
some loose connection in the wirings leads this type of problem.
Oct 04, 2008 | 1997 Jaguar XJ6
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
Error code 241
241 Central controller data sending error. Either defective CNU or Central controller initialisation failure
LG Klima Arza Kodlar pdf
Lg Air Conditioning Fault Codes
http://www.orionair.co.uk/lg_air_con_fault_codes.htm
Jun 17, 2015 | LG L1204R Air Conditioner
What type of refrigerant should be used in a Mitsubishi ms09tw 2001 air conditioner?
The answer is R410A.
Refrigerant Types in a Central Air Conditioner
There are 2 different types of air conditioning refrigerant currently used in residential cooling systems. R-22, commonly referred to a Freon and R410A, a blend considered to be more environmentally friendly, sometimes called Puron.
R410A (sometimes known as Puron), is the industry's choice to replace R-22 in central air conditioning systems. It is less reactive with the environment while having the same home cooling characteristics of R-22. R410A is not interchangeable with R-22-you choose one or the other and your air cooling equipment is designed to operate with it. When you purchase a R-410A system, a new line set is included with your central air installation as well as a new evaporator coil. Our experience with R-410A has been excellent. New cooling systems have been dependable and efficient, as well as operating quieter! R-410A is the refrigerant of the future!
Less reactive with the environment
Replaces R-22 in the year 2020
Cannot be used with R-22 systems
Quiet and dependable
Freon, R22, heat pump refrigerant
R-22 also known as Freon has been used for decades as the refrigerant in central air conditioning systems. However it has been linked to Ozone depletion and has therefore been banned from being manufactured after the year 2010. It's price will increase as the supply decreases.
Good luck,
Marty
May 27, 2014 | Mitsubishi MSH09TW Air Conditioner
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
Tipically, a hot air furnce has exhaust and a cold air intake. My question is, why is one of them hooked to condensation pump that pumps water out?
Hello
In a forced hot air system you have a supply and a return.
Now with central air cond,you also have the same supply and return exept you also have an air conditioning coil that the return air goes through to be cooled,then it is blown out through the supply side to the vents in the home.
Since warm air or summer air contians water or humidity the cooling coil collects the moisture and sends it to a pan which when fills up is pumped out by a condensation pump.
Jun 01, 2010 | Goodman GMS90703BXA Heater
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
145 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
