Question about Canon ZR70MC Mini DV Digital Camcorder
Eject button my camcorders eject button is on all the time and i dont have a manual can you help me in this area. joyce
  • 95 Answers
This is a Canon service issue mini dv camcorders have small intricate parts that are best left for the folks at Canon
Posted on Mar 26, 2010
    Champion:
  • 287 Answers
It may be posible to free the eject know from the eject switch but I would have to see it to know if this would be possible. www.megaone.com/larry
Posted on Jul 16, 2009
Sony Video camcorder CCD-TR350E Blue tape ejection button
Same has happened to me... did you solve your problem? JT
Mar 25, 2009 | Sony Video Cameras
Memory stick eject
well to record onto, switch the power button to "camera mode". this will let the camera know to record as well as take pictures onto the memory stik.
As for ejecting the memory stik, jus simply push it INWARD gently and it will spring OUTWARD toward you. to put it bac, do the opposite till the card locks into place
Jun 23, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Jammed tape in Sony camcorder
There is no manual eject.
The only way is to disassemble the camera outer shell, then remove the drive mechanism and using a 4.5 V power supply power the eject mechanism.
It takes 30 min of work when you know how to do it. If you find the service manual (free somewhere in internet) it will tell you how to open the camera.
Hope this helps.
DocG4
Mar 30, 2008 | Video Cameras
Changing to USB
I had the same error today. The solution is the manual. If you dont have the manual you can download it from panasonic. If I had my camera with me i would wlk you through the steps. Start by pressing the mune button. Just navigate through the setup area.
Jan 11, 2008 | Panasonic VDR-D100 DVD Camcorder
Panasonic camcorder NVDS 27
After a deep study of the manual there are two reset buttons. One on the remote (pg 8 #4). The camera reset is next to the tape eject button. (pg6 #25). Hope this helps.
Dec 13, 2007 | Panasonic NV-DS27B Mini DV Digital...
Eject
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
Apr 21, 2007 | Canon ES900 Camcorder
Code 32:11 will not eject tape sony tvr67
The mechanism got stuck. Open the cassette compartment screws and apply external DC to the Power input and eject the tape. If this is not possible refer to a skilled technician. If you need the service manuals and mechanism for replacement write to us.
Dec 07, 2006 | Sony Handycam CCD-TRV67 Camcorder
Tape is stuck in my Sony handycam DCR-PC101
If you turned on the power or inserted the battery while pressing the ejct on the camcorder then you have a serious mechanical control curcuit fault or a power supply thats bad inside the camcorder. Probably those small surface mounted pan caps that ALWAYS go bad. It time to take the unint to a pro to be checked unless you have all mthe speacial tools and extenstion cables to work on this camera. Good Luck
May 10, 2006 | Sony Handycam DCR-PC101E Mini DV Digital...
Hitachi DVD camcorder
The door might be stuck. Try "helping" it open manually after pressing the eject button. Otherwise, something is probably broken and you might have to call a repairman.
Apr 09, 2006 | Hitachi DZ-MV580A DVD Camcorder
Canon ZR70MC Mini DV Digital Camcorder Logo
136 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
