Question about Panasonic Office Equipment & Supplies
Panasonic Copier Good Afternoon, My Panasonic copier is leaving what looks like runny ink spots on every copy in the same place. Could you advise me what I might be able to do and what is causing this. Thank You Harold
  • 148 Answers
If the spot is in the same spot each time, then there is something in or on the glass. Make sure both sides of the glass are clean ( sometimes spots are really hard to see on the glass and may take several times of cleaning. You may have dust on the mirror under the glass. I would suggest a tech clean there.
Hope that helps...
Posted on Jun 27, 2008
Copies are light
try shaking the toner bottle up, then putting it back in.
Apr 19, 2010 | Panasonic FP-7735 Black and White Copier
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
Sep 23, 2008 | Office Equipment & Supplies
Copies paper great except leaves a long invisible 1 inch thick line down the middle
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
Feb 13, 2008 | Canon PC1061 Copier
Irregular ink spots all over the text
Are the ink spots in the same pattern down the page ? if so it sounds like a bad drum. try and make a copy using only one color at a time, to try and tell which drum it may be. If the spot are random down the page it may be the ITB belt cleaner.
Apr 17, 2010 | Canon imageRUNNER C3200 Copier
Black spots in the dram ricoh 450
Are the black spots on all copies. if they are only on teh copies done from teh glass scan then it could be dirt on the g;*** plate. if from all copies it is the dev or drum area.. are the dots moving across the page in the same place if you do lots of copies this means it is the drum that is damaged.. if they are blotchy marks it could be toner build up.. if the marks are in a line across the page open up the side door adn look at the hot roller in the fuser the coating could be damaged and the roller need replacing..GOOD luck A
Sep 29, 2009 | Ricoh Aficio 450 Copier
Pictures are coming out with ink all runny has been working fine til now
look in you manual and clean the ink jet head, sometimes "gunk" gets built up on the head and cause the pictures to come out smudged and runny.
Aug 12, 2009 | Epson Stylus 680 InkJet Color Printer
Won't print or copy (looks like it's out of ink or cartridge is jammed)
if you have the program of printer install to your comp ? then run the maintenance program , that will CLEAN , ALIGN , AND PRINT A TEST PAPER , AJ
May 08, 2009 | HP OfficeJet R80xi All-In-One InkJet...
Ar 235
Clean the scanner glass. If you see any toner spills inside of the copier, you might want to clean those.
If you look at the green drum and see toner on it after copying, it could be the cleaning blade under neath the drum isn't working properly.
If you know where the charge wires are, you can clean those off as well.
Oct 06, 2008 | Sharp AR-235 Copier
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Printer problem
You need service on your copier. It might just need a cleaning, or possibly a part. If they are random spots on your copies, then there is a good chance the cleaning unit seal needs to be replaced.
Jan 24, 2008 | Office Equipment & Supplies
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
