Question about Jenn-Air Expressions CVEX4370 Electric Cooktop
Jenn Air Expressions radiant module for CVEX4370
The glass on the radiant module is broken. I have seen replacement glass at an internet part store. Does anyone know what type of sealant is used to attach and seal? It looks like a long piece of foam of some sort with sealant on both sides??? Is this correct and does it come with the glass if ordered? Thank you. mm
Found the solution. It was a simple one duh! Six screws. After looking at the picture of the glass and realizing that the glass comes on a frame, I noticed the screws just below the glass on the cartridge. The glass frame sits inside the base of the cartridge. It took about 5 minutes. mmaque
Posted on Jun 28, 2008
How do I replace the spark module on the jenn air JGD8130ADB cook top?
It is beside the thermocoupler , Buy new one .
Remove old one .
Install new one .
Oct 28, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Suddenly my Jenn air gas cooktop ignitors (all of them) do not click and spark, the model is CVGX2423B. I suspect it might be spark module fails, is that right?
It sounds like you need a new spark module which controls all of the burners. It is part number W10475147. It costs around $115.00!
Sep 01, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Fisher and Paykel cooktop model # CE901 will not work at all. Went dead suddenly. All five burners dead. Electricity to the unit is tested and fine. Any ideas to trouble shoot?
Yes, it is the spark module. It needs to be replaced. Sometimes it's easy to reach and sometimes not. I am trying to get my hands on a Jenn AirJGD130ADB Repair Manual becasue I have the same problem.
Aug 12, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
How does one replace the spark Module on a Jennair Model CCG456 cooktop. Glass top appears to be held in place by a brass collar on each of the burner tubes. The coller has 2 small slots on it as if it was...
Sorry to read about your problem, I hope this helps you out.
yes needs special tool
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
11 year old jenn air expressions cook top
gud day,for my sujjestion is replace the unit coz if u get the part is more expensive to new one.unless is we have a rewind the motor like in the phillipines thats more cheaper to the new one,11 years is enougth for ur usage, that my sujjestion
Jan 10, 2009 | Jenn-Air Expressions AC110 Electric...
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Glass Top Replacement
There are 3 or 4 screws under the front lip; then the unit hinges upward. Turn off the power first! Once opened you can safaly remove the burners and replace toe top. hope this helps!
Dec 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air Expressions cvgx2423b manual request
I have the same model with the same problem. The replacement is simple. Remove the burner cap (no tools needed) Take a large crescent wrench and remove the large center nut holding the burner assembly in place. The ignitor will slide out of the assembly once it is removed. Good luck
Aug 14, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air Expressions CVEX4370 Electric Cooktop Logo
353 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
