Question about Fujitsu ScanPartner fi-5120C Pass-Through Scanner
Scanning speed slowed...
My scanner has always been very fast, but now it scans each page extremely slow....anyway to solve this issue?
Did you change your scan resoulution? The quality of your scans will determine how slow it will pass through. another thing to check is weather it is scanning both sides, another option in your scanner properties.
Posted on Jul 23, 2008
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
Jul 04, 2011 | Canon DR-9080C Path-Through Scanner
The scanner, which used to be fast, now runs extremely slow. It takes about a minute and a half for the Dell AIO Center software to load, nearly 3 minutes to preview, and 2 minutes to scan. So just to scan...
Scanners speed is influenced by the quality chosen in document productions. Selecting impressionful color saturation requires time to produce results. Use the menu buttons on the scanner to select least saturated color pixels.
Feb 02, 2011 | Dell 968w Printer
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
My canon dr-3080 cii is running at a low speed. it was at its maximum and suddenly slowed down. rebooted cpu and switched scanner on /off and chcked settings with no results. please help
Scanner will continue to scan at the same Speed! The problem is in the computer. Check if you have enough disk space, do a 'defrag' on your harddisk, create extra space by deleting unwanted files. IF your processor is slow and if you are scanning in color or converting to PDF while scanning, it may slow down the output.
S. Mohan, Chennai, India
Dec 22, 2010 | Canon DR-3080CII Path-Through Flatbed...
I have 6 identical new PC's running Windows XP SP3 with Kodak i1210 scanners. 4 of them are running fine and scanning fine. The two giving me an issue are scanning fine as well but they are scanning...
Please check if the disk where you are saving has enough space. Defrag the drive for better results. If you are connecting the scanners trough an USB cable, try replacing them. Also check if the file format is same. If you have chosen to scan BMP or TIFF uncompressed or Color, the file size may be too big. I presume the other two PCs are free of virus.
S. Mohan
Aug 09, 2010 | Kodak i1210 Pass-Through Scanner
Scanning is extremly slow
What interface? If it is a USB interface the scanner sends the numbers the same as if you had entered them on the keyboard. If you do just enter the barcode (need to know format actually sent to application) numbers does it also respond slow?
Plug the scanner into another PC/laptop, open notepad and scan a barcode, does it scan fast?
The POS application, if it is windows, open notepad and scan the barcode, does it scan faster.
It is likely the POS application that is responding slow.
For the POS applicaton:
- Is scan database local or on the network.
- Have you maintained the scan database? Re-index, compacting, etc
Apr 13, 2010 | HHP 3800g Handheld Barcode Scanner
Your disk must be full or you need to do a 'defrag' on the volume where you are storing the data. Initially it is stored in the buffer and when the disk writing is slow, scanning speed is affected. Clean the disk for faster scanning.
Mar 23, 2010 | Canon DR-9080C Path-Through Scanner
Scanner is scanning slow
likely your resolution settings are very high, anything scanned at over 100dpi will take considerably longer. if it were a hardware issue then the scanned document would not be readable as the speed of the rollers must be sync'd with the scanning speed for a successful scan
Dec 09, 2009 | Bell & Howell B we Bell & Howell Spectrum...
Scanning speed slows down after approx 100 pages. Is it possible to talk to a 1220 expert on phone to describe multipule problems, today?
Scanner 'slows' down depending upon various conditions. For color images and large detailed files, there may be some slowing down. The most common cause is insufficent disk space. Check where you are directing the computer to write the scanned images. Have sufficient space and do a 'defrag' done.
S. Mohan, India.
Jul 22, 2009 | Office Equipment & Supplies
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
Fujitsu ScanPartner fi-5120C Pass-Through Scanner Logo
1,363 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
