Question about ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor
Optiquest Q9 After about 14 months, my 19" LCD Optiquest Q9 monitor suddenly got very dark ( the bottom 1/4 was still viewable, though dark) and then went blank. After it cools for a while I can power it back up with the same results. There is a faint click when it goes black. I have replaced it with another 19" LCD ( different MFG.) which is working fine, but hate to throw this one away if it is repairable. The screen itself seems fine with no pixels missing at the time it went dark. There are four cards inside. A power card, a card on the horizontal axis, a card on the vertical axis and the main video card. I am not sure of the correct names for these cards. If I can get a replacemet card, which would it most likely be, or should I just trash bin this?
  • 7 more comments
  • madbob73 Jul 01, 2008
    Well Viewsonic was no help.
    I did do some reading here on similar problems and took a chance and replaced two capacitors on the inverter board. Now it works!
  • Anonymous Jul 25, 2008
    I had the same problem with my Optiquest Q9 (shortly after power-up the monitor would go dim) and tried to contact madbob73 to find out which capacitors that he replaced. Unfortunately, I did not get a response, but FORTUNATELY, after taking a look at the power supply circuitboard, there are only 5 caps. 3 X 470uF, 1 X 300uF and another very large cap. I had heard that some of the can type caps bulge when they go bad. All 4 of the smaller caps were bulged / rounded at the top. The large one was fine.
    To make a long story short, I was able to quickly get three 470uF caps at Radio Shack ($4), but was not able to purchase the 300uF cap anywhere locally. I decided to replace the 3 caps that I had and try the monitor. The monitor is now working fine! Thanks madbob73! You saved me a couple hundred bucks!
  • Jimmymcjim Dec 07, 2008
    My monitor went all dim and is flickering also. It is not a VX922, but a VS11201 (similar model). I will try checking the capacitors, and will replace any if bulging or leaking.
  • derrrick_mar Feb 08, 2009
    I have the same problem green power lights stays on but a black screen is shown and won't let me do anything. What can i try?
  • shep00 Apr 22, 2009
    All the posts made me feel brave and take my optiquest q7 apart and guess what I found..bloated capacitors! It is now at a bench tech to have the new ones put in. I am not brave enough to do the soldering cause I can't see tiny things like that.
    I will repost when I find out if it worked. What the heck, the monitor is already disfuctional and the MFG was NO help...it was only 3 yrs old. I will ck warrantys before I buy again........
  • Anonymous May 11, 2009
    I'm having the exact same problem. It started a few months ago with my monitor making crackling sounds and soon began to quickly flicker while warming up. I was hoping it would stop... unfortunately it only got worse. and after once night I began to smell I foul burning smell, immediately I shut it down for the night, ever since then the screen hasn't been the same lol. I'll check the capacitors tonight. hopefully this solves everything. I don't want to waste a few hundred dollars for a new one.
  • jonzie77 May 11, 2010
    Can anyone out there tell me what voltage the capacitors in question are? I was hoping to get them at work, preemptively, and install them tonight.
  • BillB Feb 21, 2013
    Is replacing the capacitors something a newbie can do ? Do the capcitors have to be "bled" . Not interested in getting shocked. Thanks
    Is this something a newbie can do ? Do the capacitors need to be bled or anything like that ? I'm not interested in getting shocked. Thanks, wbrunc
I had this problem with my Q9 and I was glad to find the FixYa website with help. But I will offer more detailed info for novices to make sure you find the capacitors. First of all, it is not easy trying to find out how to open the monitor up! First, set it down flat on it's face, being careful not to scratch the screen. Pop off the cap that covers the stand mount to the screen. You might also want to remove the base by squeezing the bottom tabs to the middle and pushing them out. Once the base cover is removed, you will see the 6 screws holding the base arm to the screen. Remove those and the arm will come off. Now, on the bottom right, there is a beveled slot where you can fit a flat bladded screw driver to start to snap open the case. Move around the case separating it carefully until it is completely un-snapped. Unplug the speaker cable (mine gave me some trouble but I worked it side to side and it finally let go). You can push the videop cable through the the back case to get the case out of the way. Once you have removed the back half of the case you will not immediately see the offending capacitors. You will need to remove 4 phillips screws holding down a metal shield on the power board. You may also have to remove some metal tape covering 2 of the screws. When the screws and tape are removed, you will need to slide the metal shield to the right to release it from a 3 pin connector that the two boards. Be careful that you don't damage that connector. Lift up on it a little and slide it left until the connector is disconnected. Now you can see the capacitors. I only had to replace the 3 bulging ones and that fixed my problem as well. Thanks all for your helpful comments in saving me money on a new monitor!!
Posted on Oct 26, 2009
  • jackd7780 Jan 18, 2011
    Jayw135's posting (Solution 3) is VERY helpful in taking apart the monitor, identifying the bad capacitors, and fixing the problem!!
Well... I took your advice and replaced the 3 capacitors that were "bloated" for my Opiquest Q9 monitor I bought off E-Bay and was very dim and making noises out the back... and so with spending about 4bucks at radio shack and then soldering the new capacitors on it now works perfectly!!! Saving me lots of money on buying a brand new one. This does work people!!!!
Posted on Aug 07, 2008
My monitor, sure enough, had the dreaded 3 bloated capacitors. After soldering the new capacitors in, the monitor worked like new. Thank you Madbob for the suggestion.
Posted on Dec 09, 2008
  • CrouseZoo Oct 11, 2010
    Add me to the list. I had 4 bad capacitors to replace.
    Problem Solver:
  • 10 Answers
I must agree with everyone, the first thing i always look for when something is wierd with my monitor (besides if it is plugged in) is the capasitors, its so simple just to visually look at them and check if any look different, i would say that it would be because of your capasitors too.
Posted on Jul 16, 2009
Me too. Monitor was dim & squarkley-sounding during warmup. Then it went dark altogether. Replaced the 3 capacitors and it's working fine! Thanks.
Posted on May 10, 2009
Same issue on Q9 monitor, powering off over and over again but no visible bloating of can caps. Are there other types of caps on power board?
  • billmorrell Jul 28, 2011
    If you are having noise problems / problems with display going out, go ahead and replace the caps even if they appear fine. The caps in my monitor showed no signs of bloating for any of them but I changed them out anyway and now the monitor works fine again.
    BTW, the existing capaitors are 25v 470uf and the ones I had gotten off ebay were 35v 470uf which are larger but it still seems to work fine.
Viewsonic optiquest flat panel lcd monitor power light flashes on and off with a popping niose
Look for bad caps with bulging/leaking tops as shown here:
http://s807.photobucket.com/albums/yy352/budm/OPTIQUEST/Optiquest%20Q9B/
Very common problem in all LCD monitors as you can see in my albums.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
I have a 19 inch samsung monitor. suddenly it went dark. Can it be repaired?
Please be more specific about your problem:
1. Is it black or just darker by lower brightness? 2. Is the power led turned on and what color is it showing?
Sep 14, 2011 | Samsung 19" TFT LCD Monitor...
Barely used work fine and then no power nothing Optiquest 19" lcd
You can take the unit apart, in there you will see the power supply, check the fuses(small) and check the caps to see if the tops are bluging...
Feb 25, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Optiquest q9b-2 blank white screen (lights up when powered up) no video ??no problem with computer, video fine on another monitor, tried this monitor on several computers same problem, blank white...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 06, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Arcing sound when on then goes dark. Repeats when restarted
your ribbon cable to your LCD panel has a broken spot in it need to replace the LCD
Jan 13, 2010 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Monitor suddenly went dark. Switched it to another system but still dark. Power light on. V9s S1901D S/N T34F501728
Disconnected Data cable from the monitor to the back of the CPU. Do a self test on monitor if u get colors on the monitor it is working fine.
check for loose cables. Try to do factory reset on monitor using buttons on monitor.
Aug 17, 2009 | Scanport JTX V9S (Black) 19 in. Flat Panel...
LCD Panel went dark al of a sudden
It could be a faulty inverter or a faulty CCFL lamp.
Check LCD Parts for parts, service and DIY info etc. Use this link.
www.lcdparts.net
Jul 25, 2009 | ViewSonic Computers & Internet
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor Logo
3,673 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
