Question about Sony Televison & Video
Sony FD Trinitron
In Search of documentation to support or disprove:
I am being told by a board supplier that the DZ board is interchangable with the D Board... I am looking for verification and Sony has not responded to this question.
The Part # is A1300319A.
Thank you,
Kristen
  • 4,234 Answers
The part number that you reference is teh complete D board and is available from tritronicsinc.com for $313.49 with a DUD return of $115.00 This means that you return the bad baord and get a credit of $115 when the board is received back at tritronicsinc.
I can only verify the interchange if you supply the original model number of the set involved.
Thanks,
Dan
Posted on Jun 27, 2008
Trinitron kv-27hs420 standby light flaches 7 times and it wont come on
  1. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
Jun 04, 2012 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony KD-36XS955 Will not power up... Indicator blinks 7 times repeatedly
Please replace 2 ICs on DZ board of tv to solve the issue as discussed in chat session.
Thanks.
Jul 11, 2011 | Sony FD Trinitron KD-36XS955 36" TV
My Sony KV-32HS420 won't turn on -- blinks 7 times, pauses, blinks 7 times. I've seen the same problem described on this site, and the answer seems to be that 2 ICs on the DZ board need to be replaced. I'm...
The 7 blinks on this model indicates that the horizontal section of the TV has stopped working. Horizontal Deflection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
I have the serrvice manual if you need it. Let me know where to send it to.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Stand by light flashes 7 times and tv will not turn on
Sony Trinitron Wega KV-34HS420 blinks 7 times it means the the Horizontal Deflection stopped.
There are two cause for this: B overcurrent is detected (IC5007 is defective) or there is a over heating is detected by the Thermistor (TH5002). Both of these parts are on the DZ Board. If you order the DZ Board from the "Partstore.com" it will cost you $395.95 minimum. The Thermistor TH5002 (part # 1-807-796-11) cost $4.95.
This IC chip IC5007 is no longer available at Partstore.com. You could purchase it from other stores. Not sure of price.
Replacing the whole DZ board would for sure fix this problem but at close to $400.00. Then what if another board or your picture tube goes out soon.
Better to go buy a new flat panel LCD from Costco for around the same price.
Hope this helps
Bobby Guel "aka poolmvp1"
May 31, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a Sony Trinitron KV-32HS500 that won't turn on. It blinks 7 times. I was told it was a power supply problem. What part do I need to fix this?
The Power Supply/ Deflection Board is called the "D" Board. Replacing this Board should fix your problem. You can try to order one from Sony at 1800-222-SONY. If it is not available, you will need to send it to Sony for them to rebuild it. That will cost around $400.00 or so.
I hope this helps,
Skyassoc
Nov 14, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Vega KV-34HS420
it's better if you bring you're tv to sony service center and ask to an authorized repairman
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv is on stand by mode and wont turn on
how long have you had your tv, and what i had found out is that after replacing the power supply board my tv went out a second time but i had gotten a warranty and then another power supply board was replaced and it would not come on, for 2-3days, so everyday i would just keep on pluggin it up and one day it came back on and i havent turned the tv off yet, what i was told by the tv repair man was that i needed a picure tube, and he said sony knows these tv has alot of problems, i tried contacting sony but was given the run around, i just wont by sony products anymore as they dont stand behind there product
Mar 15, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Nov 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
