Question about Nokia 5300 Grey Cellular Phone
Back light it shows the picture on the screen, but the back light only works when i slide the phone up with force for a second or two if im lucky. and if i push on the white part under the top key pad with pressure, sometimes the back light will work also.
  • 1,010 Answers
Its a screen problem...
Posted on Jun 27, 2008
5300 nokia display light not working
Usual cause of this phone is losing the flex connector on the upper board,this may happen when the phone drop off the ground or a force of sliding up/down.
To fix this problem,please follow this method.
1. turn off the phone
2. remove the battery
3. slide up the phone
4. at the back of the upper panel,pill the metal shield with a cutter blade.(it's a little bit sticky because of adhesive.)
5. upon seeing a flex connector,check if it's detach or loosen,gently push that connector until it locks or fit (be careful with the lcd in front panel when pushing that connector,might broke it if pushing over)
Now test if gonna work now.
Otherwise,it can be flex connector or LCD screen need to replace,it is more safe if you bring the phone to a mobile service shop for parts replacement.
Good Luck...
Aug 12, 2011 | Cell Phones
Hi, Sony Ericsson z310i mobile, screen is showing blank, other lights on, cannot access message or make a call, pls advice
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Take care.
Mar 31, 2011 | Sony Ericsson Z310i Cellular Phone
Hi, my N81 sometimes turns dim when i push some buttons and when i slide the screen. i dont know if its the flex because it turns to normal when i left the phone to standby or when i restart my phone.. pls...
Take care...
Mar 09, 2011 | Nokia N81
Is there a simple reason why the screen on my samsung mobile has gone blank.the phone can still turn on and off and keys still make sound when you press them as they normally do but nothing on the screen...
The problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
Take care.
Nov 15, 2010 | Samsung Lands Phones
My verixon htc VX6800 screen will not show up but the phone is on. the screen will light up black, but the home screen wont actually turn on. i can recieve calls but can't see thephone. how can i fix this...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
Take care.
Aug 02, 2010 | Verizon Communications HTC XV6800 Cell...
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
My Razr Screen Turns White After like a couple seconds. The inside screen is white the outside screen turns blue. Itll work for a couple seconds then it messes up. whats wrong?
I think the problem with your phone is that, the flex on the screen of your phone is malfunctioning and will need to be replace.
Take care.
Jul 18, 2010 | Motorola Mobility RAZR V3
My motorola v557 cell phone doesn't light up. how
Good luck.
Jul 12, 2010 | Motorola Mobility V557 Cellular Phone
Blank screen nothing shows
Good luck.
Jun 24, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
Nokia 5300 Grey Cellular Phone Logo
67 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
