FixYa.com
Tags:
Jenn-Air JCD2389G Side by Side Refrigerator
JCD2389DES Water Leak Problem (by 2 users)
posted by Gundy1214 on Jun 27, 2008
Leak seems to be from ice developing at bottom of freezer and then leaking out bottom of door as it melts or defrosts. Defrosted and removed about a inch of ice at bottom. Later ice started developing again? Have shut off water to the refrigerator thinking that was problem and water appeared again on floor underneath doors to appliance. Any ideas on why that ice develops on bottom of freezer
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jun 29, 2008
leak from under door of refrigerator
Best Solution
posted on Jul 10, 2008
FixYa! (100)
2 boobs
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
We also had this problem with a Jenn Air side by side. I cleaned out the drain tube and melted the ice in the collector tray but we still had water coming out of the freezer door later on. My wife started looking for a new fridge because she was tired of cleaning up the pudles daily. I went online to another site and found this to be a common problem. It seems the defrost cycle is not long enough to let all the water drain out of the collector tray and it ends up frozen in place and the the tube gets blocked and the the water runs down the inside back of the freezer untill it fills the the bottom of the freezer. Then it freezes and the the next time the water flows out the front of the door on to the floor. There are kits available to solve this problem and they cost about $20. I looked at what was in the kit and made my own part. It is a 9 or 10" long piece of # 12 or #14 copper wire (house wiring ground wire).
Turn off fridge and take the shelves out of freezer and then take off the large grill on the back wall and melt the ice in the bottom area where the metal water collector tray is. Look under the fidge where the evaporator tray is and make sure water is in fact running down the tube. To make sure it is, empty out the evap tray and put it back in and pour water into the defrost collector tray to see if the water flows down to the evap tray. If it doesn't then blow it out. If it does then take the copper wire and shove all but 2" of it down the tube that drains the collector tray. The last 2" or 3" of wire needs to be bent 90 degrees so that it lays flat in the tray. It seems the cooper wire that is down inside the tube conducts enough warmth from outside the freezer to keep the tray from freezing up to soon after the defrost cycle and lets all the water drain out down to the evaporating tray which is under the fridge. We never had water in the evaporating tray before because it was never making it down the tube. It has been many months now since my fix with no water on the floor.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
There is a grill at the back of the freezer which you can take off with a few screws. The water is building up on the bottom of the freezer floor as the drip tray behind the grill is blocked and will be iced over. You need to melt the ice (maybe with boiling hot water, turn off the power of course) and then unblock the drip tray drain. i used a inflatable pool pump to pump air down the drain and it unblocked it
Can you Help with these Refrigerators problems?
fridge
fridge no t geting cold Answer This...
refrigerators
5 years old refrigerator( two... Answer This...
JCD2389GES SIDE BY SIDE
Frig ran constantly for weeks... Answer This...
Jenn-Air JFI2589AEP
Three door jenn aire just... Answer This...
JENN-AIR BLOWS WARM AIR
my jenn-air #jcd2389ges ice... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
