Question about Konica Minolta DiMAGE Z10 Digital Camera
Memory card the card that came with the camera is a 16MB. it doesn't take pictures without the card. the 16MB card wouldn't stay in the camera. so i bought a 1GB card. that wouldn't stay in camera. for some reason, now the 16MB card will stay in, but not for long. but the camera still says it cannot use the card that came with the camera. should i buy another small card. or give up. if it won't take the card that came with the camera maybe, its the camera. thanks
    Scholar:
  • 39 Answers
Its an sd card right?
because if its a bigger square Compact Flash Card you could a bent pin.
I wouldnt buy another car if you have a new one and they both give the same error.
I would suggest takeing it to a repair person if there is one near where you live. I would have to see the camera myself to be able to know for sure what was wrong.
But If you can afford to then I would really suggest getting a new one before your next trip. As even if My quick fix worked or if it started working again It could start failing again in the middle of the trip.
Have you tried formatting the card?
Posted on Jun 27, 2008
16mb memory card says full only 2 pictures on card
If it really is just 16MB, then, that's about right for that camera.
You need to use about a 4GB -- that Gigabyte card to be able to hold many pictures.
16MB is just too small.
Jun 19, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Tried to take pictures of lightening last night and couldn't. My lens kept going in and out and wouldn't focus so wouldn't allow me to shoot. Then I kept getting a BUSY across the screen. ...
For this kind of pictures, Don't try to focus on a lightning, it is to quick and mabe the overall brightness is not enough for your camera to focus.
So you can try to focus on something at infinity, if you manage then, put your focus on manual before re focusing, this way you will be able to take as many pictures as you want.
You can also try to focus manually directly.
And for you information the best way to take a lightning picture is to put your camera in bulb mode, use a remote control, open the shutter and close it as soon as you'v seen a lightning.
Hope this helps.
and good shooting !
May 27, 2011 | Canon EOS 500D EOS Rebel T1i Digital...
Does the SD card come with it?
From the Amazon.com web page for this camera:
"This camera has a 3MP (2048x1536) photo resolution and 640x480 video resolution, and 16mb of internal memory expandable to 2GB with an SD card (not included)"
This means that the camera has 16MB of built-in memory (enough to hold maybe 4 pictures), so you'll need to buy a 2GB or less size SD card too.
Dec 30, 2010 | GoPro Digital Hero 3 Digital Camera
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Photo storage?
It depends on the picture resolution and the size of the memory card.
Normal JPEG 2048 x 1472 : 11.0 - With 16MB built-in memory , Fine JPEG 2496 x 2016 : 19.0 - With 16MB built-in memory , Normal JPEG 2048 x 1376 : 19.0 - With 16MB built-in memory , Fine JPEG 2496 x 2016 : 9.0 - With 16MB built-in memory , Normal JPEG 2048 x 1472 : 9.0 - With 16MB built-in memory , Normal JPEG 2048 x 1376 : 35.0 - With 16MB built-in memory , Fine JPEG 1024 x 736 , Fine JPEG 1024 x 736
The capacity of various memory cards will be similar to the above ratios.
I hope this helps.
Jul 04, 2010 | Vivitar ViviCam 3765 Digital Camera
16mb
Sixteen MB is not very much memory when it comes to digital images. I do wedding photography and it is not unusual for 1 image to take 8 -12 mb of memory. I can use up to 8 GB on one wedding. Depending on how many megapixels your camera has you may only get a few images on 16mb card.
Jun 01, 2010 | Fuji FinePix S1000FD Digital Camera
I lost the usb cable for my camera and am trying to remove images from the internal sd card. how can i do this?
For your USB
> Contact kodak store at 1 888 369 6600 ask for KODAK USB Cable, Model U-8 or simply log on to www.kodak.com/go/shop.
To remove images from the internal memory of the camera
1. Turn the Mode dial to Favorites
2. Press the Menu button
3. Highlight delete or the minus icon, then press the OK button.
All pictures stored in the Favorites section of internal memory are removed.
4. Press the Menu button to exit the menu
** Kodak CD33 has 16 MB internal memory and it has a slot for MEMORY CARD 3428db8.jpginternal memory is different to memory card. You can use the camera without memory card but it's only up to 16MB while if your using s memory card you can load up to SD Memory Card 2 GB.
16MB if camera is set to 2MP it will only take about 2-5 photos while if your using a Memory card with a size of 1GB and camera is set to 2MP about 1137 photos.
* Contact Kodak support line @ 1 800 235 6325 (23KODAK)
Nov 16, 2009 | Kodak EasyShare CD33 Digital Camera
No Memory Card
The internal memory is 16MB, anything beyond that will not be on the camera. Should be goods for a few pics. Just connect it to your computer and download them. I hope this is comforting.
Oct 30, 2007 | Samsung Digimax 4010 Digital Camera
Memory card problems
C-Series : Optical zoom lens cameras with sliding lens cover Product name xD-Picture Card *1-7 SmartMedia
3V(3.3V) CompactFlash Type M+ / M Type H Standard C-990ZS - - - X
2MB - 128MB - C-990 ZOOM - - - X
2MB - 128MB - C-960 ZOOM - - - X
2MB - 128MB - C-920 ZOOM - - - X
2MB - 128MB - C-900 ZOOM - - - X
2MB - 32MB - C-500 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-480 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-470 ZOOM X
256MB - 2GB X
256MB - 2GB X
16MB - 512MB - - C-460 ZOOM X
256MB - 1GB X
256MB - 2GB X
16MB - 512MB - - C-450 ZOOM X
256MB - 512MB X
256MB - 512MB X
16MB - 512MB - -
http://www.olympusimage.com.sg/pr/notice/1176786_707.html
check up at this website
Sep 22, 2007 | Olympus Camedia C-450 Zoom Digital Camera
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Konica Minolta DiMAGE Z10 Digital Camera Logo
69 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
