Question about Samsung Televison & Video
Our replacement samsung dlp tv lamp doesn't give us a full screen picture on any stations other than the High Definition stations, how do we fix this?
  • hammontree1 Jun 27, 2008
    our model number is the HL-4667W
    we tried the fix but got only the TV Guide on Screen Guide, no "loading factory" displayed. What next?
    Genius:
  • 1,011 Answers
Dear Sir,
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can subsitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
Thanks
Good Luck
"Don't forget to rate the solution"
Posted on Jun 27, 2008
    Brigadier General:
  • 3,614 Answers
What is the exact model/number of your TV..?
  • micromaster
    micromaster Jun 27, 2008
    is the replacement part was actually the same specs or it was the same on the part# of the one you remove..?
    if you replaced a lamp which is not meet the hardware requirements of the tv, it is possible that the problem was coming from there..
  • 405 Answers
The high def stations are full screen as they are transmitted in a 16:9 ratio which is full screen. However the non HD channels are transmitted in a 4:3 ratio which is square and not full screen. Usually this can be rectifyed by putting your tv in 16:9 mode through it's menu's. You can also adjust this setting through your cable box if you are using one.
Hope this helps
  • Patrick McGee
    Patrick McGee Jun 27, 2008
    Follow this link for the manual and refrence page 55 for picture control settings
    http://www.samsung.com/us/support/downlo...
    Hope this helps
  • Patrick McGee
    Patrick McGee Jul 01, 2008
    You can select the picture size which best corresponds to your viewing requirements.
    Press the MENU button.
    Press the up or down button to
    select “Picture”, then press
    the ENTER button.
    Press up or down button to
    select “Size”, then press the
    ENTER button.
    Press the left or right button to
    select the screen format you
    want, then press the ENTER
    button.
    Press the EXIT button to exit.
    Alternate method
    Press the ASPECT button on the remote control repeatedly to select
    one of the picture size settings.
    • “16:9”: Sets the picture to 16:9 wide mode.
    • “Panorama”: Use this mode for the wide aspect ratio of a
    panoramic picture.
    • “Zoom1”: Magnifies the size of the picture on screen.
    You can also move the picture on screen using the
    scroll function. Press the … or † button to scroll the
    picture.
    • “Zoom2”: Magnifies the size of the picture more than
    “Zoom1”. You can also move the picture on screen
    using the scrooll function. Press the … or † button to
    scroll the picture.
    • “4:3”: Sets the picture to 4:3 normal mode.
    This is a standard TV screen size.
    NOTES
    • You can select only 16:9, 4:3 screen size in the Component(480p, 720p, 1080i) Mode.
    • With PIP On, the screen automatically becomes wide in the Antenna, AV (1~3), S-Video (1~3)
    or Component (480i) mode. With PIP Off, it returns to original screen size.
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
I have a Samsung 42" DLP. During the daytime I can hardly see the people and definition on the screen. It is all very dark. Nightime is better.
check your video settings there are 3 or 4 usually that all have various levels of brightness, it may be set to one of thelower ones. or you can go into tv menu and try kicking up the brightness. if no luck the lamp may be failing if not recently replaced they begin to make screen darker before they fail.
Jan 23, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung DLP hln567w tv has NO picture on all
If the Lamp ignites and stays lit, but screen is completely black, not even the on screen display, then it is likely a bad DMD board.
If the lamp ignites and then turns off after a couple seconds then it is likely the color wheel is seized.
If the lamp never fires, but the TV clicks a bunch of times, then it could be a bad Ballast or the Lamp itself.
Sep 18, 2009 | Samsung DLP HL-P5663W 56" TV
Display problem with my Samsung HLP5085W DLP TV
What you are describing sounds like a tuner issue. Samsung had a run of bad tuners, and was recalled. If your watching a chennel and the image tears, this is the sign of the bad tuner. It is possible that the wobulation circuit is unstable. First units we bothered by subwoofers thumping the TV. Not much help other than that, good luck
Jul 07, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
