Question about Husqvarna Designer I
Problems recalibrating Designer 1
I need to recalibrate my touch screen on my designer 1, but it is so far off, I can't even get the touch button to come up! It's picking up items that are about 2 rows down....help! I'm about 50 miles from my sewing tech, and I need to get up and running again!
Paige
  • pdgaines Jul 07, 2008
    I tried this but nothing happens....when I touch the calibration marks, it does nothing. Is it time for me to take it to the repair shop??
    Thanks for your help...if you know of anything else I can do, please let me know.
    Paige
    Problem Solver:
  • 16 Answers
Switch on while holding in reverse & pivot buttons. release then press needle stop button. calibration marks will appear. set & restart.
Posted on Jun 28, 2008
On my Husqvarna Designer 1 sewing machine the screen is not centered so when you push one design another come up. How do reset?
Check your owner's manual for calibration instructions. You're wanting to recalibrate the screen.
Jan 30, 2018 | Husqvarna Sewing Machines
I cant remember how to recalibrate my baby lock esante ESe.I found the answer before but didn't write it down.Now it is out of calibration again and I can not find how to do it. Please someone help. I
Turn off machine. Hold in the 3 buttons above the needle. Turn machine on. Voila in screen calibration mode. Using touchpen carefully touch numbers 1-5 in order. repeat until you hear beeps. turn off machine. restart and your good to go.
Oct 01, 2014 | Sewing Machines
Touch screen unresponsive
Whats the model number and type? A designer with the large touch screen can lose its programming on the screen and needs recalibrating. Models can be different and some have codes that need to be entered. Respond to this with the info and I will look it up and reply.
Derek
Jan 21, 2011 | Husqvarna Sewing Machines
Designer 1 Problem
Try touching around the button on the screen.  Touch above, below,left & right moving farther away from center. At some point it may clear. If so, use the same method to calibrate your touch screen in the "set" menu.  If not, go back to your repair facility and have them recalibrate in the service mode.
Sep 03, 2009 | Husqvarna Designer I
The touch screen is scrambled and frozen
Are you saying that nothing at all happens every time, or sometimes you get the wrong thing i.e. you touch Prog and Rep screen comes up? Have you ever recalibrated your screen? This should be done regularly - at least every six months, but I do mine monthly. The catch is that in order to do this, you need to access the Set Menu and if your screen is not responding at all this would be impossible. In the Set Menu on the last page (I think) there is a "Color Touch Screen Adjust" button. Use this to access the calibration screen, and you must touch exactly in the centre of the two crosshairs until they turn green. Instructions are on Page 31 of my manual.
Mar 07, 2009 | Husqvarna Designer I
Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Feb 25, 2009 | Husqvarna Designer I
You probably have the old-style touch panel which is known to fail. Viking has a five year warranty on electronics but sometimes they will cover this particular part beyond the five years. If you find a sympathetic dealer you may be able to get the part for free. You will need to pay for the labor though.
Feb 05, 2009 | Husqvarna Designer I
Screen is frozen
Dec 26, 2007 | Husqvarna Designer I
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
487 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
