Question about Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher
Fridgidaire dishwasher pld2560lcc
Hello, Does anyone know why the soap dispenser will not open sometimes using dry dishwasher soap or when it does open the dispenser cup still has soap left inside?  Thanks Jeff
  • Frigidaire Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
Posted on Sep 30, 2010
Our dishwasher is not dissolving the soap. Has anyone else had this issue and does anyone know how to fix this problem?
Try using a liquid dishwasher detergent.
Also, if you are using dry detergent (that is not pre-measured in pods, etc.), you may be overfilling the detergent dispenser. When the dry detergent gets wet, it swells and causes the detergent dispenser door to stick.
Apr 13, 2016 | Frigidaire Dishwashers
Fridgidaire pld4375rfc0 detergent dispenser not opening
Hi leeroyf - If the soap is not dispensing all the way out then usually the sprayer arms are not able to reach that area of the unit and door. I recommend making sure that the area is clean of dishes to try to prevent this issue because it sounds like something is blocking it and that the dispenser door is not stuck. Using the correct of amount of soap is also helpful. However, if problem proceeds then I suggest contacting a professional to move forward accurately since it may be having an issue with the wiring connections to dispenser and control.
Dec 03, 2012 | Frigidaire Professional Series 24 in....
The soap dispenser isn't opening all the way. Therefore it leaves a small amount of soap in the chamber after the rinse and dry cycle. How do I fix it?
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Feb 20, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dispenser door not opening and washer sometimes won't start
Jul 13, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Jan 08, 2010 | Kenmore Dishwashers
Latch cover on dishwasher soap dispenser no longer functions.
hello there. i hope i can help you?. please check the latch spray a little wd40. and give the soap dispenser. a good clean with warm water. please check that you are useing the correct soap? as this can cause alot of problems. check once a tip give the machine a good clean once a month. i hope this has helped you marymena? also please check for any little obstructions.
May 08, 2009 | Frigidaire Dishwashers
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Fridgidaire UltraQuiet III dishwasher model FDB750RCC0
First thing to check is to make sure the dishwasher is getting water.
Dec 03, 2017 | Dishwashers
Filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
Hello chystalsbrr
You said you, filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
You can try by turning off the breaker in the electric box that feeds the dishwasher for 5 minutes and see if when you turn it back on and the washer resets itself, and the soap door opens.
Or push cancel and then rinse and after it is done and goes to the dry cycle stop it and it should be open.
In the use of liquid soap in both a dishwasher and or washing machine you must use less soap. Half that of powder soap.
Or the suds will roll out of your dishwasher on to your floor. And this is not a malfunction on the dishwashers part. NO bad seal or anything!
In a clothes washer it will destroy the seal and bearing in less than 5 years!
Let me know how it goes!
Please remember to leave a rating
Oct 19, 2008 | Whirlpool Dishwashers
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher Logo
361 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
