Question about Sony SLV-940HF VCR
940HF TAPE LOADS BUT JUST FLICKERING IMAGE ON SCREEN AT START OF PLAY MODE. LIFTING THE TOP COVER. OBSERVING THE TWO SLIDING MECHANISMS WHICH DRAW THE TAPE AROUND THE HEAD. THE SPINDLE, AND ARM ON THE RIGHT IS LOOSER THAN THE LEFT. IT MOVES FORWARD, NOT FAR ENOUGH. PUTTING A SLIGHT PRESSURE ON IT, AND IT ENGAGES, PLAYING THE TAPE. ALSO THERE IS AN ARM WITH A FELT TYPE PAD WHEEL ON IT THAT WILL ENGAGE THE CENTER OF THE TAPE HEAD. WHAT IS THIS FOR?
    Novelist:
    Champion:
  • 275 Answers
If the rt guide arm is not moving fully forward, just put a couple of drops of white grease on the mechanism.
The arm with the felt pad is the autu-head cleaner pad. after a year or 2 of use, it will be more a menace than a good useful cleaner, as it will add the accumulated dirt on to the head, instead of cleaning. Just remove it.
Posted on Jul 16, 2008
Everytime I put in a tape it acts like it is going to play it stops and turns itself off
usually this is because the tape is binding. there is a lot of mechanisms that must move when loading. if one hangs up, it stops and unloads the tape. it also could be a worn or broken belt. another thing that is monitored by the electronics is the current. if something is binding, the current goes up and it will shut down. i would remove the top cover and watch how it loads. maybe you can see the problem.
Nov 05, 2016 | Televison & Video
How do i replace the batteries in this device?
To install the batteries:1. With the back of the radio facing you, remove the belt clip (seediagram below) for easy access, then remove the Battery Coverby pressing down on the top center and sliding it down from theradio.2. Insert 4 AA batteries observing the polarity as shown. Installingthe batteries incorrectly will prevent the unit from operating ormay damage the unit.3. Return the Battery Cover by sliding it up on the radio. Replace thebelt clip, making sure it locks into place.
To install the batteries: 1. With the back of the radio facing you, remove the belt clip (see diagram below) for easy access, then remove the Battery Cover by pressing down on the top center and sliding it down from the radio. 2. Insert 4 AA batteries observing the polarity as shown. Installing the batteries incorrectly will prevent the unit from operating or may damage the unit. 3. Return the Battery Cover by sliding it up on the radio. Replace the belt clip, making sure it locks into place.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Midland LXT310 2-Way Radio
Tape will not play...
After posting my request for info, I went to another forum (which I listed) and read...numerous times that when you haven't used your Camcorder for a while, mechanisms get stuck. Their advice was to actually hit your camcorder with some force several times. I thought that they could not possibly be serious. But... what did I have to lose. I hit the camcorder several times...inserted a tape and believe it or not, it played...also without any flickering.
I am so very pleased because my sister passed and the vidoe tape was of her.
I hope that this solution helps someone.
Aug 08, 2008 | Sony Handycam CCD-TRV16 Camcorder
Sony SLV-940HF VCR Problem: clicking noise when tape fully rewinds
It is normal. Sony is trying to get your tapes last longer.
Mar 27, 2008 | Sony SLV-940HF VCR
Sony reel to reel TC -765
I too had this problem with my tc765. I found the two pinch rollers were not lifting up and fully pushing the tape against the rotating capstans in the play/record mode. Solution to my problem involved partly dismantling the pinch roller assembly, cleaning off the old solidified grease and re-lubing with a molybdenum grease. Note: the top plate has to come off first,then the rotating guides and tensioning pegs. Then the cast head cover and flap. It was a time consuming operation, but well within the scope of competent DIY in my opinion.
Sep 24, 2007 | Audio Players & Recorders
Vcr problem
this usually indicates an error condition- the logic is sensing an abnormal condition. Suggest taking the top cover off the VCR, and load the tape, then activate play. Does tape begin to spill out in the mechanisms, especially towards the right side of the tape? If so, then the take up spindle isn't being engaged to take up the tape. This at least was, a common problem with VCRs, especially older ones ('80s era) which used a rubber drive wheel. This rubber "tire" like drive would become slick & hard, and would cause a no-takeup condition, spiling tape out. There was a sensor which told the logic circuit if the takeup wheel was indeed turning, and if not, the VCR would be taken into a stop or shutoff mode. This sensing would prevent large amounts of tape spillage and the resultant damage such would do. Another possible cause is the tape isn't being loaded properly. This is generally due to a defect in the carriage mechanism (the assembly which holds the tape). Often, these mechanisms were gear driven. Timing on these gears is often critical, and being off by just one tooth would cause an error.
Sep 17, 2007 | Symphonic SL260A S-VHS VCR
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
SLV 940 HF
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Aug 26, 2007 | Sony SLV-940HF VCR
Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Jan 27, 2007 | Sony SLV-940HF VCR
Can my camcorder work with imovie and if so how do i get my computer to get download my video?
Open iMovie and set it to capture DV. (Click the camera shaped icon opposed to the siscor scissor shape) When you see a blue screen that says (camera connected) and the image pops on screen of image from tape on camcorder set in play mode, you hit the import button and it begins to capture digital movie using DV compression of whatever you have on tape. You should be able to control your camcorder with the video controllers underneath the project window to make selections for the in and outpunts on the tape you wish to capture. Then switch to edit mode by clicking on the scissor button and import the movies you just captured or use them from the clips menu, etc. renedr movie back to tape, if you wish by clicking back and forth from edit mode (scissors) and capture mode (camera silo) and render to and from tape.
Jan 21, 2007 | Canon ZR700 Mini DV Digital Camcorder
Televison & Video Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
