Question about SanDisk Sansa e200 MP3 Player
Sansa e200 man i tried ur solution but it wont work the thing is that my computer wont read my device and windows media wont format this sansa device is not helping at all ur the only 1 i trust
  • Anonymous Jul 06, 2008
    windows won't recoize it
    President:
  • 2,712 Answers
There is one option, not really a fix, just a workaround. Try the player on a different computer computer and see if it is recognnised there. If it is, then use something like a pen drive to transfer music from the PC that doesnt recognise the device to another that does. Now you can transfer music using the WMPlayer sync service.
If your device is not being recognised on many computers, it looks like it is time to chuck it away. You can also try this first though..
1. Remove the player from the PC and switch it off.
2. Restart the computer.
3. Hold the +Volume button and connect to computer.
4. Keep the button pressed for at least 60 secs, and you should see the "Found New Hardware" balloon pop up, indicating that the device has been detected.
If even that fails, then I'm afraid your Sansa player has run its course, and you may need to purchase a new player...:(
Posted on Jun 28, 2008
My sansa 4.0 G mp3 player is freezing on the sandisk window
if you had a software with it install it. then if the pc reads it just format it from ur pc. if it doesnt contact ur seller. tks
Jul 07, 2009 | SanDisk Sansa e250 MP3 Player
I can not upload any music-help
Use Windows Media Player to transfer songs to your device. Make sure the songs are in the right format for your Sansa e200. iTunes, for instance, won't work with the Sansa e200 series.
-Tha Mp3 Doctor
Mar 15, 2009 | SanDisk Sansa e260 MP3 Player
P.O.S. sansa e200!!!!!!!!
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 03, 2009 | SanDisk Sansa e200 MP3 Player
My Sansa e200 mp3 player has frozen and i can't add anything.
http://www.sansa.com/support/sansa_e200/faqs
First, try resetting the device as described in question 2
SOLUTION 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
SOLUTION 2 – If the problem was not resolved, download and Install the Sansa Firmware Updater.
SOLUTION 3 – If the problem was not resolved, format the device
WARNING: Formatting will DELETE all content in the player. Please backup all your data.
Please use Windows Explorer or Windows Media Player to format your device.
Dec 27, 2008 | SanDisk Sansa e200 MP3 Player
My sansa e250 gets frozen
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
Wont come on
Make sure the hold switch is not engaged.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa e250 MP3 Player
Computer doesn't recognize MP3 player -
go on sandisk and do the updates
and changes the format of the hard drive
Mar 25, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 locks up in refresh database during startup
if the computer can find ur sansa(or 16mb format) you should rightcliick and format it. this will delete ur music, videos, etc but it will make ur player usable
Mar 17, 2008 | SanDisk Sansa e200 MP3 Player
Wont play songs
-Tha Mp3 Doctor
Oct 07, 2007 | SanDisk Sansa e200 MP3 Player
Wont let me transfer osngs
2 possibilities. Most likey you need to upgrade the firmware for your device so that it is compatible with WMP. Go to the sandisk website. find product support and download the latest fimware. install it on your player. then try using wmp again. if that doesn't work you may need to reformat the device. open your 'my computer folder' with the device connected. right click on the device icon. click format. set to FAT format if allowed. click quick format. unplug device and then power it back on. it should reboot itself.
Jul 30, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
