Question about Lands Phones
Hiphone my hiphone isnt turning on , I got it like two days ago and it was working fine now i cant turn it on and i didnt even do anything to it please can someone help me
I already have the same problem- cant turn it on...is there any solution available?
Posted on Jul 11, 2008
Serive enige soon light
That light just means the emission levels are too high,doesn't mean there is a big problem,a bad plug wire or even a loose fuel cap will turn on the light,
Dec 22, 2013 | 1999 Mercury Tracer
Hi, i have a 1995 nissan altima , When I installed my new radio deck in my Nissan , it was working fine for an hour until I turned off the car. Once I turned the car back on, none of my gauges moved, my...
flat battery isnt a good sign
no driving power =engine check light on
battery terminals tight
got 12 volt everywhere its supposed to be
was old radio linked to security or immobilizer
recheck radio wiring
1995 96 Nissan Altima Car Stereo Wire Colors
Apr 21, 2017 | Cars & Trucks
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Aug 22, 2009 | Creative Labs Zen Digital Media Player
My voyager's inside screen has gone black
do the buttons on the inside work? if so maybe you dammaged the video cable to the screen. if the buttons do not work then the phone isnt recognising that you have opened it. does the external screen go blank when you open it?
Jul 23, 2009 | LG VOYAGER VX10000 Cellular Phone
Everything has power, but engine will not crank or even click when attempted to start.
could be a bad ground cable .replace battery cables if they havent been change in a while.if it still dont crank .remove starter have it tested.at advance auto parts and auto zone. if starter good.replace starter solenoid or relay.
May 25, 2009 | 1989 Mercury Cougar
My webcam just stopped working.
Hi Peter I posted this for another probem I would suggest you follow these steps but as I don't know the model number of your laptop please start here but please make sure you get the correct drivers first, (uninstall the old drivers and programe first then reinstall) : )
Camera Utility for Windows Vista (32/64bit)
Hi the first place to go is the Toshiba web site?
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2029137&rpn=PSMD0U&modelFilter=M300-ST4060&selCategory=3&selFamily=1073768663
This link above is for model number M300 ST4060 there are 3 M300 modles ST3402-ST3403 and the above ST4060 please sellect the correct model enjoy : )
May 06, 2009 | Toshiba Satellite A355-S6925 Notebook
Hiphone internet setup
Try this. Depending on the HiPhone though, it may not work or may be different.
Create Data Account:
  • Select Menu
  • Select Services (Sometimes, Entertainment > Services)
  • Select Data Account
  • Select GPRS
  • Select an empty profile
  • Set the Account Name to T-Zones
  • Press Options
  • Press Done
  • Set APN to wap.voicestream.com
  • Press Options
  • Press Done
  • Leave Username and Password blank
  • Set Auth. Type to Normal
  • Press Done
  • Press Save
Create Profile:
  • Select Menu
  • Select WAP
  • Select Settings
  • Select Edit Profile
  • Select a profile
  • Choose Edit Profile
  • Rename Profile to T-Zones
  • Set Homepage to wap.myvoicestream.com
  • Set Data Account select GPRS
  • Select T-Zones
  • Set Connection Type to HTTP
  • Set Proxy Address to 216.155.165.50
  • Set Port to 8080
  • Leave User Name Blank
  • Leave Password Blank
  • Press Done
  • When prompted to SAVE please select Yes
  • Select Activate Profile
  • When prompted to Activate Profile please choose Yes
  • Press Done
May 30, 2008 | RIM BlackBerry Pearl 8100
Canon pixma 530
unplug it from power and plug it back in.
if that doesnt work try unplugging it and GENTLY try moving the ink carrage to make sure it isnt in some odd position that the porinter cannot detect.
IF the carrage is properly seated on the one side of the printer it is normal for it to be locked and seated on pads that keep the ink from drying out.
May 02, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Washers isnt working
Most probably its your belt that has come off. Open up behind to check and refit. If belt is too loose, replace. The belt should "give" about half an inch after it is fitted. Or it would be too tight or too loose.
Dont forget to rate me please.
Dec 27, 2007 | Washing Machines
My display outside and inside isnt working for my motorola razr v3
bring it to a technician, and let him know what the new battery and charger did to your normally fine phone. They should be responsible for repairing your phone. No easy fix as described above. Let me know how it works.
Cynthia Charczenko
Nov 04, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
105 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
