Question about Bissell Vacuums
How to install a new water pump on a big Green machine?
I have replaced this pump before, and had the pump "seize" again. I hooked the output of the bissel to a siphon pump to pull a vacuum while i had the input hose (with the little filter) submerged in a bucket of water. After i got the pump started, I submerged both the inlet and outlet hoses (after the trigger handle) into a bucket of warm water and turned the spray switch on to circulate clear water through the whole deal
Posted on Dec 08, 2009
My Bissell Big Green barely sprays any water.
Check you User Guide and see where the filters are. They usually have have a filter under the flow indicator. Turn the Flow Indicator cap counter-clockwise to remove it. Lift out the rotor and the filter is under it. Remove it and clean. Reinstall in reverse order. I don't know anything about the specific machine you have but I know they have a flow indicator from other comments I've read so it's worth the try.. Hope that Helps.
Jul 22, 2015 | Bissell 86T3 Big Green Clean Machine
How much will it cost to replace a leaking pump or is it best to buy a new washer
I am assuming this is a washing machine. Not knowing the model, most machines have the pump underneath it and it is accessible if you can set the machine on its side. Make sure that the water is drained out of it first. You might want to take it out to an area where a spill of water from the machine won't matter. The pump is connected with two hoses and it can be belt driven or mounted directly to the motor. It is not too difficult to remove and replace. Having the part with you when you go to purchase a replacement is good. Be sure to take photos before you remove the pump. This will help the memory when you go to install the new one.
Mar 21, 2011 | Vacuums
My little green machine won't dispurse the water. what could be wrong?
You can disassemble the unit and check to see if the pump motor has seized.
the motor has a black, red and green wire attached, is encased in a plastic housing, and is right next to the vacuum assembly. Don't cut the line attached to the plastic housing, you don't need to and it can be a pain to reattach later. just slide the whole white housing up towards the black vacuum assembly, and undo the wire leads attached to the motor, they just pull off (make sure it's not plugged in) making sure to note which wire attaches to which lead... i marked each lead with a colored marker to be sure.
Use a pair of pliers to turn the drive shaft if it has seized, and be sure not to lose the small rubber o-ring that sits around the shaft. Lubricate at the base where the drive shaft meets the motor with just a drop of 3-in-1 electric motor oil and then reassemble the housing, attach the leads, seat the motor back into the seating (make sure the bottom nozzle goes into the green water feed coupler!) and reassemble the case.
worked well for me, if it still doesn't work you could buy a new pump and install it. they go for around $10 on ebay and amazon.com
Jun 24, 2010 | Bissell 1400 Little Green Pro Canister...
Not putting out water
Here's some trouble shooting tips that will help you figure out what's wrong with your Bissell Little Green Machine, and why the water won't spray out. You didn't mention how old the machine was, but if the machine is brand new, and you've never used this before, then you'll need to prime the machine for the first time.
To prime the Little Green Machine, remove the hose after filling the clean water tank, and press and hold the trigger on the hose for approximately 45 seconds. This will prime the pump, and get the water flowing.
If the machine is older, and you've already been using it, here's some other troubleshooting tips that you can do to try and fix the machine:
Step 1. Fill the clean water solution tank with water, and remove it from the machine. With the tank removed, press the piston at the end of the tank that fits into the machine. The piston is the spring loaded part in the top of the water tank that is pressed upwards when the trigger is squeezed, which in turn releases water into the machine. Press the piston inwards with your finger and see if water comes out.
Step 2. If water is released from the tank when you push the piston inwards, then your piston and cap assembly are fine. Next unscrew the cap to the clean water tank and make sure that the o-ring is present. This is the rubber ring that rests in between the cap and the tank.
Step 3. If your o-ring is not there, you'll need to purchase a new a new o-ring and replace it. If the o-ring is present, screw the cap back onto the tank. Inspect the receiver to make sure there is no debris blocking it. The receiver is the part on the machine that the tank sits on top of. If you see debris here, remove any debris that could be obstructing the tanks piston.
Step 4. After checking these three things, refill the tank with water, reinsert back into the machine and test to see if the water now comes out. If the water does not come out, move on to step 5.
Step 5. Unscrew the two screws on the handle of the hose, and remove the cover that the two screws secure.
Step 6. After removing the hose cover, inspect the hose that connects to the trigger assembly for blockages:
Step 7. If blockages are found, remove the tube from the trigger, and blow through the hose to remove any blockages, and reinstall the tube back onto the trigger.
Step 8. Reinstall the trigger assembly so that the metal spring's curved side is facing down so that it touches the trigger valve:
Step 8. After reassembling the hose, turn the machine on again and try spraying the hose again.
If none of these solutions fixed your machine, this most likely indicates that you need to replace your pump. The pump is the internal part that takes the water from the tank, through the hose, and finally sprays it out. The pump replacement is a moderately difficult repair, but if you'd like me to walk you through it, I'd be more then happy to do so.
Please feel free to ask any follow up questions, or let me know if you'd like for me to show you how to replace the pump. I'm always more then happy to answer any question that you may have.
If you found this helpful, please kindly rate my repair helpful so that other Fixya users with the same problem can easily find this solution. By rating the repair you are also encouraging repair professionals to continue posting free repairs. Thanks in advance,
Chris J.
GoVacuum.com
Apr 09, 2010 | Bissell 1400 Little Green Pro Canister...
I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (ie on...
I got my Little Green ProHeat when the product was first unveiled several years ago. Shortly thereafter, the nozzle itself developed a clog in the spray jet. Remove the nozzle from the end of the hose, and with the machine running pull the trigger. If a great amount of solution comes out of the supply hole, then your nozzle is clogged. You can try clearing it with a very thin pin and then rinsing it out.
In about 6 months, my pump would no longer spray solution at all but I could hear the tiny pump still running inside the machine when I would pull the trigger. Remove the tanks, unplug the unit, and look carefully and you will see the few screws holding the unit together. Pull it apart carefully and don't use much force as some of it snaps together and you don't want to break those tabs. Once open, you can find the solution pump, a little fella. The drive shaft on the motor that spins the pump had rusted away completely! Design flaw. In lieu of getting it repaired, I simply started using a spray bottle for my solution application. Several years later and I'm ready to take the time to replace the pump - a very simple process. From the research I've done, the part number for the solution pump is:
Manufacturer's Part Number: 6035029
If you google search "Bissell 6035029 VacPartsWarehouse" without the quotes, you should find your part there for around $9.
Try this direct link to VacPartsWarehouse's website:
VacPartsWarehouse Bissell 1425-2 Little Green ProHeat
Click item #9. It's very simple to install. If you can wield a philips screwdriver, and pay attention to how you've disassembled the unit and then just reverse the steps, you can fix this yourself on the cheap.
Good luck! :)
Dan
May 29, 2009 | Bissell 1400 Little Green Pro Canister...
Big Green
We found that ours had a simpler problem. Upon opening the motor compartment, we saw that the pump had "nudged" up from it's mounting slots. It is held down by a clip on each end and one had pushed up, allowing the pump to ride up and thereby disconnecting the short hose which kept the "suction train" intact. Once we re-seated the pump correctly and pushed the clip back down, the hose reached nicely and our suction was re-established.
Getting into the motor and pump area was the hardest part. Inside the power hose "cubbie" is a small hex head screw. Find your shortest stubbiest 1/4 inch open ended wrench to loosen this screw (lefty-loosey). Once the screw is out, gently pry along the edge with fingers and thumbs. The top (ours is green) part should separate itself from the bottom (ours is beige) part. The pump in our unit is red and has a 4-5 inch hose leading from the end of the pump to the outlet (on the outside of the green or top part). Re-assemble and go for it!
Mar 20, 2008 | Vacuums
My Bissell Big Green does not spray water, It just stopped.
You may have a bad pump or the heater if your model has one, may be clogged, not allowing water to flow thru.
Big Green Machine
Go to Bissell.com and see if a user manual is available for download. You will need your model number tho.
Jan 09, 2008 | Vacuums
Bissell Big Green Machine Model 1672 will not pump cleaning liquid
have a Bissell Big Green 1672, the older canister model. Went crazy trying to figure out how to get to the pump. Finally figured it out. The top green "shell" covers the motor & pump and is separate from the "grey" plastic housing. Using a screw driver, insert it between the small gap between the top "shell" and the housing. If you look at it with it laying down on the top, you will see the small 1/4" gap. Gently pry in between the two and work your way around. It will start to lift up and then you can easily work your way around and it will pop off exposing the motor and pump. Note that the wires to the on/off & pump switches will sill be attached to the top shell. If you take them off note where they came from and make sure they are all on when you put the top back on. I have had my Green Machine for years, what a work horse! To bad they don't make them anymore, the new ones that replaced them just don't have the same durability and power as the older Green Machines.
Dec 19, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
135 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
