If you are asking ,will my car work,or not if i delete the alarm system control. I honestly don't know about that one,you might need to contact a dealer,or ford servace department. I hope this helps you!
SECTION 412-04: Control Components
2000 Escort Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 08/04/1999
Control Assembly
Special Tool(s)
Remover, Audio Unit 415-001 (T87P-19061-A) Removal
Disconnect the battery ground cable (14301).
Rotate the temperature control switch to the COOL position.
Disconnect the A/C temperature cable (19988) from the heater core housing.
Unlock the heater temperature cable by pulling down the tab.
Disconnect the heater temperature cable while holding the tab down.
Use the Radio Removing Tool to pull the integrated control panel out of the instrument panel (04320).
Disconnect the vacuum harness from the function selector switch.
Disconnect the radio antenna lead in cable (18812) and the electrical connectors and remove the control assembly.
sounds like a bad install. disconnect fuse to radio amp or remove power from amp as to not drain the battery. have a pro check out your security sys. better safe than smoke!
disconnect the bonnet switch under the hood behind the right headlight .should stop the alarm.let me know how you get on with this.will the doors open manually with key in door.or they wont open with remote as you did not specify
