Question about Maytag MER6769 Gemini Electric Kitchen Range
F9-2 error code
Please help me disable this code so I can use this stove & oven.
Thanks,
Vicki
  • 1 more comment
  • Anonymous Sep 30, 2008
    f9-2
  • tatejack Nov 19, 2008
    I have the same problem F9-2 code. It happened after cleaning the top oven. Please help me fix this.
  • Anonymous Dec 05, 2008
    I got an F9 error message on my Maytag stove. What does this mean?
5 Suggested Answers
SOURCE: stove and oven not heating---display works. no error codes
faulty element
Posted on May 13, 2007
elhomspam
  • 58 Answers
SOURCE: Maytag gas super capacity plus
F9 relates to a bad door latch
either you need to reconnect a rod
or you have a bad latch(sometimes solenoid asembly depends on age)
Posted on May 02, 2008
  • 333 Answers
SOURCE: I have a model mer6872baq,can't
Follow this link and may find what you are looking for. I hope this helps.
Posted on Nov 30, 2008
SOURCE: Maytag Oven MER5770AAA gives F9 code and won't
F9 is a door latch problem.Check the door latch components.It actually means that the machine is not detecting the door closing.There might be some purchase of parts to rectify this problem.
Posted on Apr 10, 2009
SOURCE: What does F9 mean? Won't allow me to use the oven
F9 -It is a Door latch fault code
Check door latch components.The stove is not detecting a proper door close.Or else there might be some metal blocking the door from closing.It should solve itself in few hours else you might have to replace the door latch system.Good luck with the machine.Please do post comments.Also do rate the solution.Thank you in advance.
I'm getting error code AM71 UI75 EEKGO-097 on my kitchenaid stove. The oven is not turning off unless I unplug. Please help.
I'm not sure exactly what that error code means, but being a technician I can tell you the control board and the oven sensor need to be replaced. The control board simply because it tells the oven what to do and when to do it, the sensor because its a rule of thumb because the two work hand in hand and because its a cheap part and with the situation has more than likely taken damage of some sort.
May 07, 2012 | KitchenAid Stove / Oven / Range Infinite...
I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 26, 2010 | Frigidare GLEC30S8C 31 in. Electric...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F3 error code on stove has disabled the oven from opening. I need help in opening the oven and advice as to how to prevent another occurrence. The stove product number is 790.75761002 this however isn't...
The oven temperature sensor is bad. Open the oven look in the back wall of the oven on the top right or left side.There will be a 3 inch piece of metal sticking out,slightly smaller than a pencil thickness. Unplug the range. Remove the screws from the sensor and pull it out to disconnect the wiring plug. Install a new temp sensor.
Nov 10, 2009 | Kenmore Cooktops
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
GE profile gas stove over does not work....F7 D8 on screen
spectra stove and it is beeping and reading f7 we have unplug it and replug please help me
Nov 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Maytag MER6769 Gemini Electric Kitchen Range Logo
230 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
