Question about Maytag MER6769 Gemini Electric Kitchen Range
I CANNOT TURN OFF THE "LOC" MESSAGE
I TURNED THE OVEN ON SELF-CLEANING MODE. AFTER IF WAS DONE THE "LOC" APPEARED ON THE SCREEN AND IT'S BEEN LIKE THAT FOR OVER AN HOUR NOW. HOW DO I TURN IT OFF? I LOST MY INSTRUCTION MANUAL.
YOUR REPLY WOULD BE MUCH APPRECIATED. THANK YOU. We have the error code f9-2 and we have reset the breaker and that didn't fix it. What now?
  • 1 more comment
  • Anonymous Nov 16, 2008
    on my ge built in oven, I went ot clean it yesterday and all I got was the LOC display on the keypad, even when I touch every button. The doors aren't locked. I just can not get this LOC display off of the key pad and work my oven. I turned off the circuit breaker, all night and it still won't display anything except LOC after touching each key on the pad, itself
    loc DISPLAY WILL NOT GET OFF THE KEY PAD PANEL
  • Anonymous Jan 07, 2009
    after using the self-clean option and this was finished, the lock device will not turn off. the control board first said "f1". We called the dealership, and they said it was the clock and sensor and it would cost $300 to repair. After the call, the "f1" went off and now it just stays on lock. We unplugged it for 1/2 hour, and it still says lock and we cannot open the oven door.
    Brigadier General:
  • 6,966 Answers
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (a couple of hours). Of course doing a hard reset erases all glitches as well as user settings and configurations, the unit will revert back to factory default 9assuming no hardware fault).
Maytag Error Codes:
LOC - this means configuration setting changes will not be allowed F9-1 Latch lock upper F9-2 Latch unlock upper F9-3 Latch lock lower F9-5 Latch unlock lower F9-6 Latch both lower
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 27, 2008
  • 13,433 Answers
    Sergeant:
  • 243 Answers
Give me a moment to locate the manual and i will be glad to assist you. It could be the board has gone but its hard to say. give me a moment to look up the model and i will be able to assist you further.
  • Nathan Ayers
    Nathan Ayers Jun 27, 2008
    okay i found the manual for you.
    “F” PLUS A NUMBER AND THE
    MESSAGE: “CALL AN AUTHORIZED
    SERVICER OR 888-462-9824”*
    This is called a fault code. If a fault code
    appears in the display and beeps sound,
    press the CANCEL pad. If the fault code and
    beeps continue, disconnect power to the
    appliance. Wait a few minutes, then reconnect
    power. If fault code and beeps still
    continue, disconnect power to the appliance
    and call an authorized servicer.
I am not sure you mentioned the brand you have but I have a GE profile range and the fix was as simple as pressing the 9 and 0 keys on the number pad at the same time. The range should beep and the loc turned off. Hope this helps.
Posted on Oct 10, 2008
  • tom b
    tom b Nov 04, 2013
    This solution above worked: "pressing the 9 and 0 keys on the number pad at the same time. The range should beep and the loc turned off". I hit clear, opened the door, then hit 9 and 0 together. Cleared it.
  • 487 Answers
This might have been caused by heavy soil in the oven during clean cycle. Unplug machine for 30 minutes. Plug back in ans hold any key or cancel key predd in for 1 whole minute. that should take care of it.
  • eric bosman
    eric bosman Jun 27, 2008
    Manual does not say much about it but the solution I gave should be the right one
How do I turn the temp down after oven has been on for a while. 'Loc on' message is showing and will not allow me to turn oven on.
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
Feb 13, 2017 | Ovens
Electrolux oven wont work after cleaning
Hi ja1078063,
I understand you having trouble getting your oven to work after using the self-cleaning mode. Does any part of the oven work? Confirm a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc.
Does "Loc" appear in the display if any button is pushed?
The Oven Lockout feature automatically locks the oven door, prevents most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked.
Best Regards,
Jan 22, 2014 | Electrolux EW30EW65SS Stainless Steel...
Oven doesn't heat
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 17, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
Sep 06, 2011 | Maytag Kitchen Ranges
The LOC on messsage appears on the screen when we go toturn the oven on. NEED the OVEN. What could we do to fi it?
The control lock has been activated. This feature is useful when you are cleaning the panel so that you don't accidently start the oven or the self-cleaning cycle. Try pressing Bake and Broil Hi/Lo together for 2 seconds (or a bit longer). SF should appear in the display. Then press Self Clean and Start. (When you press Self Clean the LOC message should disappear.)
Manuals for most GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click Submit. The direct link to the manual for the JTP18WWWW is: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981140017.PDF .
I hope this helps.
Jun 02, 2011 | GE Profile JTP18 Electric Single Oven
How to self clean...no owner manual
Before cleaning, remove the racks and other items in the oven. Clean the oven frame and door frame outside of the gasket with a nonabrasive cleanser like Bon Ami. Wipe up any excess grease or sugary and acidic spills by hand. Turn off the oven light. Ventilate the kitchen well.
Then press the Clean pad once for immediate start. Press Auto Start to increase the cleaning cycle to three hours. Press a second time to get a 4 hour cleaning cycle or three times to return to the two hour cycle. Cleaning and LOC plus the cleaning cycle time will be displayed on the oven. After the cleaning cycle is complete, the Cleaning will no longer be displayed. However, the LOC will remain on until the oven cools down (approximately one hour). You will not be able to open the oven until the LOC message disappears.
Press the Clean Pad twice for a delayed start. Then use the Auto Start button to determine the delay for the cleaning cycle. The rest of the steps will remain the same.
The manual is available from the following site: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JES9800A&siteCd=JA_EN_US&userType=Consumer .
I hope this helps.
(these directions are from the JES9800AAW unit; the above site has the manual for this and the JES9800ACW.)
Jan 09, 2011 | Jenn-Air JES9800A Electric Kitchen Range
F9 Error during self cleaning cycle
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 31, 2010 | Ovens
. THE MESSAGE APPEARED WHILE I WAS CLEANING THE
F1:-4 Runaway Clean Lower oven Check oven temperature sensor, replace if necessary
Nov 09, 2009 | Maytag Gemini 30" Self-Cleaning...
F-10 code and continuous beeping
Your board is going bad
Aug 25, 2009 | Ovens
Maytag MER6769 Gemini Electric Kitchen Range Logo
1,034 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
