Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
Cant install os
How can i get this pc to boot from cd
  • pod21 Sep 09, 2008
    hi i tried what you said now all i get is updating escd&verifying dmi pool data
  • 99 Answers
Hi...what pc, what operating system, etc????
However the first thing you have to do is get into the BIOS (by tapping the delete key repeatedly while going thru the initial boot-up), then makeing sure that the BIOS is set so that the first boot device is your cd drive....you should be able to boot from a cd after that...let me know!
Posted on Jun 27, 2008
  • Larry Miller Sep 09, 2008
    Before i can give a solution, i need to know what is in your computer as far as hardware goes and what operating system you are trying to install...
    i suspect it is a hardware failure of some sort...
Booting problen
first off does it come up with any error messages like no MBR found or no HDD found
if so install Knoppix cd or dvd version to a disk or a usb.
if you are unsure how to install knoppix to disk download universal usb installer and select the knoppix iso image.
once you've done that go into the bios and change the first boot device to either the CD/DVD or USB if it boots from either than your PC is fine you will need to reinstall the OS or replace HDD.
if you can see HDD in knoppix there is no reason to Replace HDD
if you cant boot to either of these try taking one stick of ram out and swap them between dimm slots
Dec 16, 2013 | Compaq Evo D31vm Pd1092 Pc - No OS -...
Working on a Dell 530 Desktop, installed a new WD 500gb Sata Hd and after setting up Boot in cmos cant get by following Boot to CD Boot Device not installed enter ready to continue. Need Help OS CD in in...
Go back into the Dell CMOS and try reseting all settings back to default. Restart and when it starts to boot, start tapping F12 to get to the boot menu. Try booting to the CD drive now.
***Please rate if this helps you or ask more detailed questions for more help. Thanks
Dec 15, 2010 | Dell Computers & Internet
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
Reinstalling
Hard drive has bad sectors on it which is why its giving you that message even though you can go thru the restore. Normally going thru the system cd and then the recovery cd should bring you into windows with the device drivers installed.
Dec 10, 2009 | Acer Aspire 5520-5156 Laptop
My machine cant load any OS on to or from the harddisk.it keeps looping when the safe mode boot page comes when the hdd has an OS. cant load any other OS from another hard disk. it works though with a...
I think BIOS does not having a problem only the hard drive or data corruption takes place on your drive. Use your unit's repair system. Or using installer cd to repair the damage.
Since you can boot to Knoppix try to view the hard drive contents. If it is readable then data corruption is a strong possibility. In Knoppix 5.1 drive letter is HDA1 I think for the first drive partition.
Oct 27, 2009 | Fujitsu Siemens SCENIC E600 PC Desktop
How do i install an oparating system in an acer laptop 4230 samueul
to install OS in laptop,its like to install OS to PC.
1.Set up Bios <with pres key "Delete" or "F1" or "F2">Booting Priority (chose Boot from CD/DVD Room).
2.Save and exit (with pres "F10")
3.Wait until text > "Pres any key for Boot from CD/DVD..." you pres any key before the text disapear.
4.and follow the instruction...
Aug 03, 2009 | Acer Aspire One A150-1006 Notebook
I disabled video card now my monitor is black. i can see the boot screen. i can hear my desktop when it loads. i tried safemode(it never loads in safemode)...last known workig....i still cant see anything.
Kindly repair or reinstall your Operating system. It has a file that has been corrupted. To avoid the damage become big try to repair it or reinstall the OS without reformatting or erasing the files save in your hard disk.
Kindly follow the steps below:
To repair/Reinstall your operating:
1. Insert your CD installer into your DVD/CD Rom then reboot your computer/Laptop.
2. Press F8 or F12 to enable boot sequence and display it in order to select the boot. Then select the DVD/CD Rom boot. Or Press Del to enter CMOS and set the boot configuration sequence and select the DVD/CD Rom as your priority to boot the system.
3. *** soon as message will display "Press any key to boot CD" then press any key to boot CD. Then wait for the CD to load all its components.
4. After loading all its components kindly follow the instructions givien by the installation wizard. Note that if you where ask by the installation wizard to press r to repair or enter kindly select enter then let the system detect the existing installation of OS in your system then it detects then press enter then kindly select "Repair" to repair the detected OS or Select "Don't make changes and make it intact" then enter to reinstall the OS without erasing the files save in your hard drive.
5. Kindly follow the instructions given by the installation wizard to finished the installation or repair of your system OS.
6. If you don't want to repair/reinstall by your self then you can contact a technician expert in computer to fix it for you.
If you need more assistance kindly reply to this post.
thank you
geo_jonas
Jul 30, 2009 | Acer Aspire™ T180 PC Desktop
Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Feb 19, 2009 | Dell Dimension C521 PC Desktop
Formatting probem
your os cd gone bad, try to get another os cd and boot the system from that cd.
Oct 28, 2008 | Computers & Internet
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
