Question about Canon MP970 Photo All-In-One InkJet Printer
Error: U150 the following ink tank cannot be recognized
The tank is installed properly, has ink in it, has worked in the past but will not at this time.
  • johnvb Sep 14, 2008
    I have the same problem (U150) on a MP970 with the Photo magenta cartridge, despite it's nearly full. No issue. Impossible to print even in black!!
  • 421 Answers
Only thing you can do with the U150 error is replace the tank.
Posted on Dec 05, 2008
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
U150--cartridge is not reognized
If the following error occurs "The following ink tank cannot be recognized" error code U043, U140, U150
Action 1 : The ink tank is not installed in the ink tank. Install the ink tank. Refer to "Replacing an ink Tank" below.
Action 2 : The ink tank is not compatible with the machine. (The lamp on the ink tank is off.) Install an appropriate ink tank.
Refer to "Replacing an ink tank" below.
Replacing Ink Tanks.
Action 3 : An ink tank error has occurred (The lamp on the ink tank is off).
Replacing an ink tank :
Replace the ink tank using the following steps :
1) Open the Paper Output Tray.
Put your finger in the rounded indent of the Paper Output tray and open it gently.
2) Make sure that the machine is turned on, and lift the Scanning Unit (Printer Cover) until it stops.
The Print Head Holder moves to the center.
Caution : * Do not hold the LCD or the Operation Panel.
* Do not hold the Print Head Holder to stop or move it.
Important : If the Scanning Unit (Printer Cover) is left open for more than 10 minutes, the Printer Head Holder moves to the right side. Close and reopen the Scanning Unit (Printer Cover) to return the holder to the center.
3) OPen the Inner Cover.
Caution : Do not touch the metallic parts inside the machine.
4) Remove the ink tank whose lamp is flashing fast.
Push the tab and remove the ink tank.
Important : * Handle ink tanks carefully to avoid staining clothing or surrounding area.
* Discard empty ink tanks according to the local laws and regualtions regarding disposal of consumables.
Note : * Do not remove more than one ink tank at a time. Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare the replacement tank.
a) Remove the new ink tank from its packaging.
b) Pull the orange tape to peel off the protective film.
c) Remove the film completely.
Important : Make sure that the protective film does not remain in the air hole. If the air hole is blocked with the remaining film, ink may leak out or may not eject properly.
d) Remove the orange protective cap from the bottom of the ink tank.
Discard the cap once it is removed.
Important : * Do not touch the electrical contacts on the ink tank. Doing so can cause the machine to malfunction or become unable to print.
* Be sure to remove the clear film from the ink tank in the exact order, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
* Do not squeeze the side of the ink tanks as this may cause the ink to leak out and stain your clothes and hands.
* Do not reattach the protective cap once you have removed it, Discard it according to the local laws and regulations regarding the disposal of consumables.
* Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
6) Install the ink tank.
a) Insert the front end of the ink tank into the Print Head. Make sure the position of the tank matched the label.
b) Press on the "press" mark on the ink tank until the ink tank snaps firmly into place.
c) Make sure that the ink lamp lights up red.
Important : Install all the ink tanks to print. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note : Make sure that the Inner Cover is closed. Printing will not start with the Inner Cover open since paper cannot be fed properly.
8) Gently close the Scanning Unit (Printer Cover).
Caution : * Be sure to hold the Scanning Unit (Printer Cover) firmly using both hands, and be careful not to get your fingers caught.
* Do not hold the LCD or the OPeration Panel.
Note : * When you start printing after replacing the ink tank. Print Head Cleaning is performed automatically. Do not start another operation until the machine has stopped making operating noises.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
New black cartridge. won't print.
your housing may be not clean try to cllean it and clean the back of the tank carfully and erinstall the tank and reset the printe4r. if not try to use the old one again and see if you get the same error
Nov 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
It appears U150 the following tank cannot recognized.. All ink are full
has anybody a solution for these crappy ip6600d canon printers constantly getting the u150 error, i've got a brand new canon catridge but to no avail, it still complains.
Jun 24, 2008 | Office Equipment & Supplies
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
INK TANK
U150 is a 'faulty electronic chip on the tank' error. If you installed a new Canon OEM tank then probably the chip on the new tank is bad.. Take that tank back for a replacement.. If you installed a Clone(non-OEM) tank, then that one will only work if you retrieve a chip from a known good OEM tank and glue it on to it. Clone(non-OEM) tanks all come without chips.
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP970 Photo All-In-One InkJet Printer Logo
670 people viewed this question
old marine
old marine
